I have a pioneer pro 1000hdi that i have replaced the power board in it is a 3rd generation plasma from them and needed the upgraded board it came in with 5 red blinks which in a 3rd gen indicates faulty power board further research led to a article mentioning upgrading any 3rd gen to a rev. h power board which we have done now we have a blink code unique to the tv and not listed in the service manual it flashes red turns green then goes blank and repeats and tv stays dead any help would be much appreciated thanks in advance
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
sherrie
michigan
I followed the solution e-mailed to me. My 50 in. phillips magnovox plasma had no sound or picture. I removed the back panel of the tv ( 55 screws) and removed the circuit board in the center of the tv. There are about 5 or 6 wire connections that you have to unplug, but they are all different in size so it's ot a problem when reconnecting. Take the circuit board to a tv repair shop. There are 2 capacitators side by side at the bottom center that were bulgeing. 3300ua 10 volt. I had them replaced by the repair shop while I waited. They had (1 ) 25 volt and (1) 16 volt available. The voltages do not have to match each other. The higher voltage is better. I put the tv back together and HURRAY!!! it works. I have been searching for a solution since last summer, Thanks to fixya.com my problem has been solved. It only cost me $35.00 total.
I thought the tv was going to the curb, thank god I didn't toss it. I hope this solutions works for the endless number of people who have posted this same prolem. GOOD LUCK!!!
Posted on Feb 12, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
REPLACING THE POWER SUPPLY PIONEER PRO-1540HD
It is not an easy to do work, as you assume. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Have pioneer pro-950 hd plasma tv. Has been working great. turned on this evening and got a display saying Plasma Display - starting up. please wait. nothing happens? can't find anything in the manual...
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
Oct 20, 2010 | Pioneer Elite PRO-950HD 42 in. Plasma...
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Jan 04, 2009 | Pioneer PureVision PDP-5040HD 50 in....
Hook up
The Pro 1000HDI has 1 HDMI input while the pro1000HD does not. Get a good set of component cables and that will upscale to 1080I you'll be fine
Aug 11, 2008 | Pioneer PureVision Pro-1000HD 50 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
Oct 28, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
