Question about Ruud UBHC Air Conditioner
When the system starts it sounds like something is falling off
The system cools fine and otherwise all is well but when it kicks in it sounds like something like the compressor is falling off. After a few seconds everything sounds fine. The original dealer has looked at it and says that is normal which I cannot believe.
  • 456 Answers
I would not worry, unless it is a distinctive sound that you just started
to notice. I can walk down a street and here units kick on all the time.
However I am trained for those sort of things.
If your unit is mounted to the side of your house on metal brackets, it is
possible that someone did not install isolation vibrators
Posted on Jul 13, 2010
Handler runs fine but the outside unit, it will kick the fan on for a sec and then shuts off. It does it over and over. sounds like something isn't turning on? what's going on?
Sounds like a bad relay on the fan , if the compressor is trying to start and stopping that kick the fan on and off. That could be due to a low charge if the unit is not cooling properly.
If the unit is cooling properly it is probably a bad relay or contactor on the fan motor.
Other possibility is the fan motor is over heating for one reason or another and if its thermally protected it will automatically shutdown. If thats the case then you need a new motor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 19, 2013 | Goodman Heating & Cooling
I have a 2000 Lincoln LS. I've changed the thermostat, and replaced the hoses but my car is still overheating. Is there something I might be overlooking?
Make sure your cooling fan kicks on.
Otherwise, it sounds like a possible leak...maybe a weeping water pump or a leak in the heater core.
Hope this helps...
Aug 15, 2011 | Lincoln LS Cars & Trucks
A snap and a sound of something falling in (inside) the back of the television ocurred while watching last evening. The sound remained on but the picture went. This is a huge TV that I cannot more and it...
That snap was most likely the lamp. Before replacing, make sure the cooling fan is operating otherwise the new one will overheat and go as well. Lamp is easy to replace.
Jan 12, 2011 | RCA Televison & Video
My car idles high in the morning when I start my car and it takes about 10 minutes before it is warm enough to put into gear, otherwise it will kick into gear hard which could mess up my transmission.
Sounds like it may be time for some maintenance. Have the radiator and cooling system flushed(if you wish to do it yourself, you can buy a chemical at any auto parts store and follow the instructions). Once the cooling system has been cleaned and prior to refilling, replace the thermostat. Refill the system and bleed as necessary. Be sure to turn the heater on full blast as you're bleeding the cooling system. It should also make your heater and A/C a little more efficient.
Mar 31, 2010 | 1992 Lexus Ls 400
I started my 2006 suzuki gsxr 600 for the first time since fall and it starts fine in neutral but as soon as u put it in gear it shuts off. The kick stand is up and it will not start in any other gear but...
check the kick stand switch...it sounds like it sticking out....so even when you put the kick stand up the switch is stuck out....so the engine wil cut out as it thinks kick stand is still down....give it a spray with wd40...or something like ....but work it till it no longer sticks.......
Mar 08, 2010 | 2006 Suzuki GSX-R 600
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
A/c unit is not blowing cool air. I took it apart and cleaned all the coils, but it still is not cool. There is also a sound like something is trying to kick on but it just kicks right back off.
sounds like the compressor is having trouble starting. this could be the start components or the compressor itself. if the fan is running when you hear the "kicking in" noise it is you compressor, they are generally PSC motors, that require a capacitor to start, the capacitor could be bad, or the compressor may need a start kit added to it, they are available to the public at most appliance parts houses, you will need the model and serial number of the unit to select the proper one.
Jul 30, 2009 | LG LWHD1800HR Wall/Window Air Conditioner
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Ge fridge not cooling
Are you sure that the compressor is running? If it is and you have no cooling it sounds like you have a leak in the system and there is no gas left. Most refrigerators have a 5 year warrenty on the sealed system. If you fall into the 5 years you may want to call GE. also there is a electronic control bord that comtrols the unit that could also be defective causing the compressor not to start. Good Luck hand hope this helped you some.
Jul 13, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ruud UBHC Air Conditioner Logo
44 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
