I have a york central air closet unit. As the ac comes on water starts to build up in the drip pan but does not drain properly.
    Problem Solver:
  • 9 Answers
Inspect the drain hole in the pan for obstructions also find somthing long, thin and flexable to snak out the drain line. These collect all kinds of debris and can clog.
Posted on Jul 12, 2010
WATER LEAK BOTTOM OF UNIT
If this is a central AC, the
condensation drips off the cooling coils into a pan. From the pan, it is suppose to either go into a drain directly or into a sump, which in turn pumps it into a drain. Dirt or mold frequently plug the drain out of the pan or the drain line itself. You need to clear the drain with a wire or forced air. If there is a trap in the drain line, it may be plugged. If there is a trap and the line is not draining from the trap into a sewer, then I suggest you remove the trap, which is intended to block sewer gas from coming up the drain line. If it doesn't drain into a sewer, there is no sewer gas to block and the trap is unnecessary. The credulous building code requires the trap, regardless of whether or not the unit drains into a sewer.
If you are talking about a window unit, the problem is similar - the water is being blocked from where it is supposed to drain. With a window unit the water is usually picked up by the fan that cools the
condenser (hot coils) on the outside of the unit. The fan sprays the water on the hot coils and evaporates it so it doesn't drip out of the unit.
Oct 04, 2012 | Goodman CKL49AR49 Air Conditioner
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
All my other AC Units have had a drain directly to the sewer system...usually connected under a sink. Does my Ruud unit only have the drain to the outside of the house? Usually, when the AC is draining...
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Aug 08, 2011 | Ruud UBHC Air Conditioner
Hi. I have an older York air handler (Model N2AHD14A06C) with an A-coil installed (G+HC036AA) that seems to be draining inside the bottom of the air handler more than the drain tube; as I have water on the...
There is no manual that can be obtained but if you google York/Johnson Controls to find your local supply house a new pan can be ordered, but your pan could debris build up down the sides or underneath where the coil meets the pan that is causing the water not to devert back to the condensate drain line connection. Also you could block off the condensate drain line and fill condensate pan with water to check for cracks or deteration in the pan itself.
Jul 05, 2011 | Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
Locating Ruud Central Air drain pan?? Water has started dripping through the ceiling from the Ruud Central Air Unit...can't find drain pan?
the drain pan is physically inside the indoor unit.
grab a 1/4" nutdriver and open the bottom service panel your coil and drain pan is there, you won't be able to remove the coil properly but you could see if the system is overflowing causing your flooding problem, let me know what you find
Jun 22, 2009 | Heating & Cooling
Pan missing when RUUD unit was installed causing problems with AC
I think your talking about an emergency drain pan. Is condensation building up on the outside of the unit? If it is, it means that the unit is not draining properly and the is too much water sitting in the main condensate pan. If you don't have the emergency pan, then the condensate drips from the unit onto the ceiling in your attic. I'm assuming a lot of things but this is what I think you are asking. You will have to find an ac supply company that will sell you an emergency pan and then it must be piped to the outside of the home or it can be plugged but with the use of a float switch. This switch will shut the unit off if the main condensate drain becomes clogged. You should have a professional come and wire a float switch unless you are knowledgeable about a/c equipment. I hope this answers your question.
Apr 01, 2009 | Heating & Cooling
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
