Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need to know the high and low settings on husqvarna35
    Brigadier General:
  • 4,088 Answers
Turn both jet needles CW to stops (lightly), then turn each screw out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to idle. Hope this helps!
Posted on Jul 13, 2010
How do I know expansion valve,a c is working correctly
you need a set of manifold guages. de pending on temp. these numbers could be different but when working proper I would say up to 100 degrees your low side should be about 40 to 45 psi and high side should be around 250 psi. if the high side is low and the low side is high then the expansion valve may he clogged or Tha accumulator could be clogged
Jul 17, 2015 | Cars & Trucks
The element goes from low to high unpredictably and must be turned off
replace the switch controlling that element. that should solve you problem.
Nov 26, 2011 | Roper FEP310 Electric Kitchen Range
My 2004 madza 3i high and low beam are too low. I have to use high beam to see the road. Is anyone know how to fix it?
This is not hard to fix. Wait until it is dark enough outside to clearly see your headlight beams, then park your car on level ground 20 feet from a wall, fence, garage door, etc. Turn on your headlights (be sure your high beams are off) and open the hood. on the top of each headlight assembly you will find an adjustment screw... just turn the screw with a Phillips screwdriver until the hot spot in the center of your headlight beam hits the wall where it meets the ground.
Nov 22, 2011 | Cars & Trucks
I have a sunbeam slow cooker model # 2690 . I do not have the manual and would like to know what dial settings mean. there is off , then I , then II , then a weird diagram .
I is low
II is high
the diagram means that this setting does 2 hours on high then 4 on low. i think its 4 on low but i know for sure its 2 on high
Aug 09, 2011 | SUNBEAM PRODUCTS Crock-Pot® Slow Cooker...
Which setting is high, which is low?
4 hr setting is the highest setting then as hours go up setting goes down. Hope that helps.
Dec 14, 2008 | Rival 38601 Smart Pot 6-Quart
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
Older model General Electric crock pot
The auto button is ususally it startts off on high setting to warm up the crock and when it reaches a pre set temperature it will shift to med or low which ever is the next lower setting it will continue cooking at this setting unless you change it
Dec 31, 2007 | Crock Pots & Slow Cookers
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
137 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Mike Squire
Jay Finke
Jay Finke
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
