Question about Sony Ericsson W600i Cellular Phone
Alexander espinoza Ono Shut stays white screen at the beginning and not start
Where can I find info on how to change the flex cable on my phone ( i have the same prob).
thanks bajan
Posted on May 19, 2008
    Brigadier General:
  • 7,752 Answers
Change the flexcable
Posted on Apr 20, 2008
Monitor will not shut off, goes to a white screen
Your unit isn't grounded..Check your main pin connector cable to make sure the connections are tight
Apr 20, 2014 | TMI Products Vizualogic Headrest Pair...
I have a GE 31GT740 31" TV That turns itself off and then back on every few seconds. There is now a broken (dashed) white line that goes from the very top center of the screen to the right side. The...
I would be concerned with the vertical IC. This IC has pins that have separated from the board itself. You will note the area under the vertical IC is almost black. It will do no good to resolder this. You will need to replace the vertical IC with a new one. And be sure to replace those electrolytic capacitors near and next to the vertical IC. Bad grounds on the this IC will cause your TV to shut down. Also inspect the rest of the TV board. In some cases the retrace cap will always need resoldered! But please inspect all areas of this board for bad grounds and resolder as necessary! Good solid grounds will give you a dependable set. Thanks for asking and show a few hands of support!
Mar 13, 2011 | GE 31GT740 31" TV
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Nuvi 225W shuts off as soon as it comes on
Well, I had a similar experience with a nuvi 1300, and perhaps my solution will work for your unit.
I tried holding my power button for 10-15 seconds, which forces it to start, but mine (like yours), would begin starting, get stuck on "Loading Maps." and then shut itself off.
I had to plug it into a USB port of a PC, and it started up for the purposes of data transfer, (not the normal startup). I then unplugged it from the PC and it restarted properly.
Give that a shot and see if it works.
Apr 12, 2010 | Garmin nuvi 255W GPS Receiver
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
Same thing
The white screen could indicate a bad inverter or the screen itself.The screen staying black could mean the video card has gone out.
Jul 28, 2009 | Acer Aspire 5670 Notebook
Dell monitor goes white when computer shuts down
does the monitor stay white after shut down or does it go back to a black screen?
Jun 26, 2009 | Acer Aspire One PC Notebook
Sony Ericsson W600i Cellular Phone Logo
506 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
