Question about TurboChef TORNADO Electric Oven
How Can i change Motor in TurboChef Tornado
I would like to know how can i change the blower motor in TurboChef Torndo Blower Motor
    Scholar:
  • 75 Answers
Its an easy fix although expencive for the parts. Just remove the rear blower cover then the six 1/4" nuts and it will come out.
Posted on Nov 01, 2010
Turbochef problem with door and magnetron blower
First aligning the doors on these ovens are a pain. In the service manual there is a whole chapter on doing this process. Contact turbochef and buy a manual for 30 bucks.
Second the mag fan should operate for 4 mins after the cook cycle has completed to continue cooling the mags down. If it goes longer than this then the control board chip needs updating or you have a bad mag fan relay.
Mar 03, 2012 | TurboChef TORNADO Electric Oven
Turbochef loud noise
You have blower motor bearing problem. If it only make noise during cooking Thanks Please rate me
Nov 14, 2011 | TurboChef TORNADO Electric Oven
I have tornado electric oven.My blower motor is keep making noise(seems that it is getting more power to run).I checked motor resistance and its okay.Any suggetions
Until the oven receives cook commands, it will continue to cycle until you give it a command.
Turn it from idle mode to off mode. Should be in your user manual page 11...
http://www.turbochef.com/filemanager/23/Tornado_Owners_Manual_NA_EU_NGC1006_G.pdf
FixYa Support
Aug 23, 2011 | TurboChef TORNADO Electric Oven
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
Problems with TurboChef TORNADO Electric Oven f8 erro.
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Jan 21, 2010 | TurboChef TORNADO Electric Oven
F8 code ?
your oven is not heating up fast enough
make sure the blower motor is working right and then check the high limit thermostat it is located on the back left of the oven
My turbochef tornado gives an error messag of
this is simple to fix but usually costly sorry to say.
F1 blower means the motor is not running when commanded.
first check the motor and verify if it spins freely - if the motor does not spin freeely remove the obstruction or replace the blower part# NGC-1025
just to clarify its the big blower behind the cook chamber not the little fan in the electrical compartment.
Dec 30, 2009 | TurboChef TORNADO Electric Oven
F1 blower fault comes on after a few seconds of warming
try replacing the blower motor speed control board. That is the most likely cause of this. The fan does go out, but very rare
Nov 02, 2009 | TurboChef TORNADO Electric Oven
F1 blowout
F1 means there is a problem with the blower motor.
1. Is air blowing into the cook chamber?
2. Do you hear rattles from the motor?
3. The 4-pin connector represent the windings in the motor, each should not measure more than 2.6 ohms. This is located back left corner on the motor controller board.
4. In front of that pin is the line voltage pin. There should be either 208 or 240 VAC across the blue and brown wires.
These are some quick troubleshooting tips....hope it helps
Apr 03, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
211 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
