Question about Nintendo DSi Black Console
My cousin's DSi screen broke
My cousin's DSi bottom screen broke, so she can't use it any more. Where can she go to get it fixed??? HELP!
    Problem Solver:
  • 16 Answers
Try all those electronical stores like jbhifi and harvy norman
Posted on Jul 13, 2010
Nintendo DSi bottom screen flashes then dies
You almost certainly have one or more blown capacitors on the board (probably just one). You will need to open it up, find the blown capacitor (convex top, instead of flat), and replace it. If you are unsure about doing soldering work on a board, get a friend who does this kind of thing. It's not expensive.
Nov 27, 2014 | Nintendo DSi Matte Blue Console
My son said he spilled soda on his dsi... it didnt get that wet but i think he dropped it. The bottom screen is a little faded and has lines in it. it still plays. is there a way to fix the lines?
No there is really no way to fix it unless if you ask the creator of of the dsi because the drop sorta cracked the screen of it. Depending on the side, top, bottom, back, where ever, it still cracks not necessarily crack but it has been to the point when it can't be fixed. The same problem happen to me except the case was that I dropped it a little more harder and the screen totally went black.
Mar 04, 2013 | Nintendo DSi Matte Blue Console
Touch screen is not responding and can not play any games.
Perform a recalibration as soon as you notice a problem, to prevent performance errors.
If the calibration problems do not go away you may need to contact Nintendo for technical service or if you think you can replace the screen you self i can give the process to do so...
How to Replace a Nintendo DSi Touch Screen
Finding someone to fix a Nintendo DSi touch screen can be time-consuming and costly. However, with the right tools, you can do it yourself. Even if you've never tried fixing anything until now.
Instructions
things you'll need:
* Tri-wing screwdriver
* Precision Phillips screwdriver
* Precision flathead screwdriver
* New Nintendo DSi touch screen
Turn the Nintendo DSi over and find the five screws on the edges of the bottom. Take each one out with your tri-wing screwdriver. In the center you will find an additional screw that will need to be removed with a precision Phillips screwdriver. This keeps your battery in place.
Take the battery out. Underneath it you will find two screws that must be removed with the tri-wing screwdriver. After both have been taken out, pull up on the bottom casing to access the motherboard. In order to replace a Nintendo DSi touch screen, this will have to be removed.
Detach the right and left buttons in the top corners by pulling up. Underneath each one will be a spring---make sure you don't lose these. Then remove the four screws in the middle of the motherboard with the precision Phillips screwdriver.
Look for the ribbon attached on the bottom left corner of the motherboard. Take a precision flathead screwdriver and pull up on the black bar that connects the ribbon. You should be able to slide it out by pulling back.
Find the two small connectors that are locked in with two tiny clips on each one. Lift up on all four clips to pull out the underlying connectors. Take out the motherboard and turn it upside down. Now you are ready to replace your DSi touch screen.
Detach the Nintendo DSi touch screen with your fingernails. Pull it away from the adhesive, one side at a time. Take the new screen and peel away the protective plastic before replacing it. Line it up where the old touch screen was and reassemble the Nintendo DSi.
Hope it helped...
Aug 15, 2011 | Nintendo DSi Blue Console
I own a Sylvania 6620LDF 20 in. EDTV-Ready LCD TV/DVD and my cousin punched the screen and a big amount of color lines are popping out no image comes out, crak is still there, tv can still turn on but no...
When he hit the screen, he most likely broke through the protective glass screen and broke the lcd screen that displays your picture. It's probably better for you to just replace the tv itself, it'll be more costly to repair the tv than to replace it.
Mar 06, 2011 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
The health and safety screen stays on my dsi
That can mean many things.
  • The buttons could be out
  • The touch screen might not work
  • The DS is freezing
  • Ect...
The best advice I can give you is to look on the bottom for the Nintendo hotline number. Call them and they can help you trouble shoot/fix your problem, and if its in warranty; fix it for free (if its out of warranty they could do it for as little as $30 if you're lucky)
Mar 02, 2011 | Nintendo DSi White Console
HI, I have a Nintendo DSi and i had gotten a R4 sim card. When i put the game in and turn my dsi on it goes to a black screen and says an error has occured. Press and hold the power button to turn the...
Have you checked that it has the right software running the card?
there was a problem with the latest software download, you may need to change it to an earlier one.
Nov 27, 2010 | Nintendo DS Console
Nintendo dsi screens show no signs of power, but blue light is on?
your ds is completley broke you either have to go to a gamestore like gamestop,ebash u know those places to get it fixed or buy a new one.But most places dont sell ds lites anymore so youl have to buy a dsi or get your ds fixed somewhere
Feb 20, 2010 | Nintendo DS Lite Console
Nintendo DSi Black Console Logo
89 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
