Question about Frigidaire FES367 Electric Kitchen Range
Oven What exactly does 'open probe connection' mean and is it something that I can fix? Thanks
  • soapchick Apr 21, 2008
    Thank you for your help in this matter. I am going to contact customer serice and get somebody over here.
    Soapchick
It relates to the temperature probe inside the oven. We had set the oven on 'MaxxClean' and 3 hours into the cycle the F30 Error occurred and the door remain locked and the oven and burners inoperable. The Service technician tried replacing the circuit board under the control board .....that didn't solve the problem....door still locked.....then he could not unlock the door to the oven. Result: we're getting a new oven in week #50 of the one-year warranty! good luck.
Posted on Apr 20, 2008
"kitchen aid model KeBS107SSS00 enter probe temperaure keeps coming on. I am not using a probe and it won't let me enter convec or normal cooking temperatures." Not my wording but it was the exact problem...
This happened on our Kitchenaid electric stove/oven as well! I unplugged the oven, opened up the outside panel of the oven (same side as the temp probe jack) and found a small metal tab adjacent to the jack. I opened that up to reveal the jack surrounded by moist fiberglass sheeting. A boiling pot of beans had over-flowed on that side of the range the day before. Moisture had gotten down in there and was crossing the connections. Once I dried off the exposed metallic parts and moved the moist fiberglass away from the connections, problem went away. Hopefully, a good self-cleaning cycle will dry up that moisture.
Sep 03, 2013 | Kitchen Ranges
On my GE jkp27w0w2ww i keep having F5 and F3 appear almost everytime i cook. I turn off the oven when it happens and then turn it back on and it usually happens again. Is there something I can do, and what...
F3 is usually an oven temp sensor. Replace the sensor. (pencil shapped probe at back top inside oven) It usually can be replaced from inside the oven by gently coaxing the plastic connector through the hole behind the sensor. Sometimes, it is only the plastic plug connecting the sensor. A possible bad connection can be eliminated by usings ceramic (high heat) twist wire connectors to make better connections.
Jan 02, 2011 | GE JKP27 Electric Double Oven
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
What does F4 mean, oven shuts off and code comes up?
The code indicates an Open or shorted oven temperature sensor. Solution is replace oven temperature sensor Here's a link to a short tutorial on how to make the repair... http://www.applianceaid.com/changingoventempsensor.html
Oct 18, 2009 | Whirlpool Ovens
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Oven will not come on after replacing the probe. still gives an f3 code.
Hi
Thanks for using FixYa. F3 error code means the oven temperature sensor (above 3000 ohms) is open and you need to check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. If there is no wiring problem then you need to replace sensor. Please also check resistance of oven temperature sensor.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Gas range. Oven does not work and F30 alarm displays.
Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a kenmore elite that has a f30 error can i fix this myself
Dec 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Frigidaire FES367 Electric Kitchen Range Logo
121 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
