Question about Kitchen Ranges
Looking for the operating manual for a WFS43W-1 stove / oven from white westinghouse. Anyone can help me?
    Master:
  • 791 Answers
First, I'm Not a westinghouse tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
Posted on Mar 12, 2018
  • 3 Answers
SOURCE: westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Posted on Feb 08, 2008
for the 8 button control ovens, white-westinghouse
turn both knobs to the lock setting (it looks like a padlock)
select the timer button (a clock with a line under it)
Increase the timer to 3 hours for heavy cleaning, 1 hour for light cleaning.
Then press start, (looks like a man running)
After cleaning let the oven cool down for 45 minutes
Hope this helps!
Posted on May 12, 2008
mnwarfield10
  • 452 Answers
SOURCE: Not sure of model and have no manual. Stoves
it sounds like your flame safe devives is gone have it checked by someone quilifed.....
Posted on Dec 30, 2009
  • 221 Answers
SOURCE: i have an old double oven white -westinghouse
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Posted on Jan 30, 2010
SOURCE: I have a 1950's westinghouse electric stove and I
I have a 1950s westinghouse electric stove for sale with the original owners manual in mint condition... please email me if you are interested... mgsromaniello@yahoo.com
thanks and i look forward to hearing from you
Posted on May 03, 2011
Stove pilot is on but oven wont light?
How do you know the pilot is on? Most likely if actually burning gas pilot, you have a bad oven thermostat. or perhaps valve. If your question is about the light switch itself, that is a different issue and somewhat confusing.
Feb 27, 2015 | White-Westinghouse White Westinghouse...
Where can I find the manual for WHITE WESTINGHOUSE model WW105. Thanks in advance.
Options I can think of:
1. Contact your local Westinghouse reseller, and ask them to purchase it
2. Contact Westinghouse directly http://westinghouse.com/customer-care/
3. Use their troubleshooter here http://www.westinghouse.co.nz/Troubleshooter
May 08, 2014 | Washing Machines
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Need owners manual for a westinghouse wfs84w 1 stove
Please call up the help section of the website given below for your requirement of the manuals/support.
http://westinghousedigital.com/contact-us-2/
Dec 10, 2010 | Ovens
I have a 1950's westinghouse electric stove and I am looking for parts. Specifically the heating element for the oven?
Jul 27, 2010 | Kitchen Ranges
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Jan 29, 2010 | Kitchen Ranges
I'm looking for an instruction manual for a Stoves 900 GTF built-in fan assisted main oven. Can you help?
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Westinghouse self cleaning oven manual or owners manual
Dec 08, 2007 | Kitchen Ranges
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
