Question about Brookstone Surround Sound Earbuds Headphones
Brookstone wireless headphones have static along w/ tv sound
Sound is clear intermittently as I move around, but not consistent. Have moved sensor away from other tv wires which helped but did not eliminate the static. HAS to be close to TV to plug in!
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Posted on Nov 25, 2015
4 Suggested Answers
SOURCE: just bought the brookstone wireless tv headphones.
just received Brookstone Wireless TV headphones as a gift, trying to connect to Samsung Hi-Def mode HLR5067WAX/XAA. There is not 'headphone' jack so I connected the 3.5 mm to a pigtale for a RED-White cable.... any one have information on where the R-W cable is plugged into for sound???
Posted on Nov 25, 2010
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
Posted on Dec 28, 2011
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Tip
Sony wireless headphones
i had a problem with too must static noise lots of hiss, i moved the headphone amp away from my x box as that was makin the problem. NOTE that ur tv can make a problem too or pc wot ever but problem shoved.
on Aug 14, 2007 | Sony Camcorder/Audio/Video 900MHz Wireless...
The head phone jack is causing crackles and static noise and not a clear reception. I move the earbud jack around to get the right sound. Is there a way to permanently fix the headphone jack port?
It is very possible that the problem lies with your headphones and not the player. Have you tried to use a different set of headphones to see if that fixes the problem?
Jun 17, 2011 | SanDisk Sansa Fuze MP3 Player
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Mar 17, 2010 | Brookstone Surround Sound Earbuds...
I am recieving weird sounds only noticable when speakers or especially headphones are connected to my audio jack. This includes static from downloads and moving my mouse.
do you have a wireless phone close by wireless phones are bad about making sound through your speakers whenever they recive or send information, also goto the advanced settings of your sound properties
Oct 26, 2009 | Dell Latitude D620 Notebook
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Jan 02, 2008 | Sennheiser RS 140 Consumer Headphones
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
Brookstone Surround Sound Earbuds Headphones Logo
437 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Marvin
Marvin
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
