Question about Acer Aspire 5102WLMi Notebook
Hard Drive in Acer Aspire 5102WLMi
I have an Acer Aspire 5102WLMi. I need to replace the hard drive. How do I go about finding a replacement that will work with my computer?
  • Stonkey Jul 13, 2010
    I don't think you are correct. When I looked at the hard drive, I'm pretty sure that it was an IDE interface. It had a lot of pins.
    I also need to know what thinkness I can use.
    President:
  • 2,571 Answers
This takes a standard 2.5" sata drive.
They are available anywhere. Here are some on Amazon
http://www.amazon.co.uk/Western-Digital-Scorpio-250gb-Internal/dp/B001IKRKO0/ref=sr_1_4?ie=UTF8&s=electronics&qid=1278958635&sr=1-4
Posted on Jul 12, 2010
  • Roy
    Roy Jul 13, 2010
    The support page i looked at must have been wrong, sorry about that.
    If it has pins then yes, it is a 2.5" ide (Pata) dive
Remove hard drive Acer aspire e1-472 laptop
In that case it is probably under the keyboard.
6 minutes into the video you can see the hdd
how to replace hard drive laptop acer Aspire E1 472 replace RAM
Mar 13, 2015 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Acer Netbook OS
if you are getting this message about corrupted partitions, you need to check and possibly replace the hard drive. There is a program to check the hard drive called Hard Disk Sentinel. It is designed for SSD hard drives like the Acer Aspire One has. Yours has a 160GB hard drive in it now.
Mar 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
I can`t start acer aspire 5102wlmi .What do I need?
Start by finding if it's a hardware or software problem by trying to go in the BIOS - if you can't then it's hardware problem. In that case check the battery first, followed by the memory and finally try to go into the BIOS without the hard disk. If even after all that the problem is not solved then it's in the motherboard or the processor - in both cases replacing them will be an expensive job for a professional.
Mar 24, 2010 | Acer Aspire 5102WLMi Notebook
Need to replace acer aspire 5314 hard drive. Where can I find one?
You need a 2.5" 150 Gigabyte drive; however, those laptops are prone to a short in the serial connection from the motherboard. This is an almost impossible task for an novice user to change a motherboard and the cost is not worth it. I installed a new hard drive and although the laptop recognized it, it still will not recognize it and load the operating system. Tested drive on another laptop and it works flawless. The hard drive became bad from the short which you can sometimes hit the bottom of the unit and make it work long enough to backup the data.
Nov 27, 2009 | Acer Aspire 5315 Notebook
BIOS problem
If the beeps have a sequence they are indicative of what might be happening. Listen to the sequence and write them down and repost.
Sep 05, 2009 | Acer Aspire 5102WLMi PC Notebook
Replacement Hard Drive
you would need a 2.5" sata hard drive. whatever size you prefer.
Apr 24, 2009 | Acer Aspire 3680-2682 Notebook
Internal hard drive replacement for an Acer Aspire 4720-4825
Try here ...I think you may like these laptop hard drives....Good Luck and let me know how it works out for you..
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=laptop+harddrive&x=0&y=0
Mar 26, 2009 | Acer Computers & Internet
Acer aspire 4315
Take out the hard drive from the laptop and reseat it back into position. Sometimes reseating the hard drive will get it to be recognized by the BIOS. After you reseat the hard drive, go into the BIOS and see if its recognized in there. If it is then try to format the hard drive. If it still doesn't see it then your hard drive will need to be replaced.
Jan 31, 2009 | Acer Aspire 4315 Notebook
I have an acer 5102wlmi (Restore)
It sounds like you have a bad hard drive. Replacing it should fix this issue.
Dec 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5102WLMi Notebook Logo
263 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
