Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
51pw9303 no picture only audio. Got the setup off channel so I no longer have ANYTHING; can't display the setup menus to get back to where I was. Is this a problem with the convergence chips, or something bigger?
    President:
  • 1,099 Answers
Convergence is not the problem because , if it convergence chips it will show colour but blurr or double image....
More than likely this will be down to your Y Sustain board has gone faulty, when the back is off your TV it is on the left hand side and will probbaly have a fuse that has blown, replacing the fuse will not solve the problem as it is the IMP under the heatsink that has gone faulty.
You should get the part number of the board,try Shopjimmy.com or Ebay for a replacement.
ALSO NOTE THAT
IF the backlights are on but you just get dim glowing on the screen when look at the screen in darkened room then the T-CON board is bad or it is not getting the 12vdc from the main logic board. Need to use logical troubleshooting before buying the wrong parts.
Hope this helps
Posted on Jul 12, 2010
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
I have no audio on two cable TV channels. Is it possible to mute audio on specific cable channel numbers? And if so, how can I get the audio back?
You cannot normally mute just certain channels. It's usually all or none. Do you subscribe to the channels that have no sound?
Dec 12, 2014 | Panasonic PV-C2060 Combo
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
Sound setting
do a set up and turn off sap in the audio setup.auto program again
Oct 28, 2007 | RCA 32F531T 32" TV
My picture went dark but the audio is ok on Philips model 51pw9303
your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
Apr 03, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
