Question about Soyo 19" LCD Flat Panel Monitor
I need a support number to talk to someone about my 19" monitor. My mointor is indicating out of signal, but I do have internet and my computer do work, I call HP first they walked me throught rebutting my computer and now they said that it's have do do with my 19" mointor. But there is no support number to call to talk to anyone. HELP PLEASE
  • 4,737 Answers
Well, before you proceed with the Phone Support, please try the monitor on another computer, if it works, the problem isn't with the monitor, or if it isn't, first change the display cable.
If you need phone support, you can select the Phone Support from the FixYa home page instead of free assistance, there's another option as Premium assistance.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Jul 12, 2010
My monitor on but no see nothing
check connections, then separate wiring. touching wires create cross-talk of signals.
Jan 10, 2014 | Gateway FPD1975W 19" LCD Monitor
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 29, 2012 | Computers & Internet
My monitor keeps saying "no signal". I confirmed
No Signal on your monitor says it is not receiving a signal from your computer... this could be:
1) the cable is bad
2) the cable is not plugged in firmly
3) your monitor is set to a different source (such as VGA or HDMI) and simply needs to have the option set.
4) the video card or onboard video electronics have failed.
Suggestion: If none of the above seem to be the problem, and if your computer AND the monitor have a VGA connector AND you have a VGA cable. Try that. If that works, its a strong indication that the DVI circuits have failed either in your monitor or in the computer's video electronics.
Aug 28, 2017 | Envision 19" Widescreen Flat Panel TFT LCD...
I have a 19 inch Gateway HD monitor. The model number is LP1925. When I boot up everything is normal. However, after about 5 minutes the screen goes black. I can't get the picture back unless I pull out...
I see that this monitor has a DVI input, in additon to the VGA input. I suggest getting a suitable cable to use the DVI input, to see if the fault replicates. If it doesn't, you have identified the problem - an issue with the analogue signal processeing circuitry in either the monitor or the computer. The monitor's auto sleep analogue circuitry, for example, may not be sensing a signal, and going to sleep. BTW, if you use a DVI-DVI cable, you avoid the video signal ever going through an analogue stage, and the image will also be purer.
Dec 16, 2017 | Gateway 19" Widescreen Flat Panel TFT LCD...
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Out Of Range
It means the LCD does not like the resolution or refresh signals from your video card. Try a resolution like 1024 x 768 at 60 or 72 Hz refresh.
Monitor Mike
Jan 03, 2009 | Star Logic 17" LCD Monitor
My mointor
Probably the LCD panel itself has gone bad. The tab board in usally the problem. The welds between the glass and board go bad.
May 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Soyo 19" LCD Flat Panel Monitor Logo
129 people viewed this question
Top Soyo Computers & Internet Experts
Marvin
Marvin
David
David
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
