Question about Zebra Office Equipment & Supplies
Any way to print zebra 140 template in the zebra 170 without any code change?
    President:
  • 1,561 Answers
If you press and hold the PAUSE key while you turn on the printer, then the test pattern used for aligning the printhead and checking for elements not working (prints a black box) will be printed.
Take care.
Posted on Jul 12, 2010
  • usaman45 Jul 12, 2010
    I am too clear my problem. I had the VB code for print label to Zebra 140 and it went ok.
    But, if I print it to Zebra 160 the label print become very small.
    Is that any way to adjust the front on the Zebra 160 to make print same as Zebra 140?
    Thanks!
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
I am printing bar codes. In the bar code it is laying down more ink then it should leaving big lines that can be sracthed off. I am using a Zebra 170 XILLL PLUS.
In the software provided adjust temperature setting of print head before printing the job. Please also check for bad ribbon. Please don't hesitate to ask if any further assistance is needed. Good Luck
May 01, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
install the correct drivers from www.zebra.com
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads.html
check if printer is connect and on.
wen finish, restart the computer, he can check automaticly.
check on START-Printers and Faxs- see the printer icon - print test page
Nov 16, 2009 | Zebra Printer 140-751-00000
How do you change the font on a Zebra Z6Mplus printer?
It has to be done in your software. You can't change fonts in the printer settings. The printer doesn't have the ability to make changes like this.
Consider this printer to be just like a laser or inkjet printer. It's just going to print what you tell it to print, how you tell it to print.
Sep 29, 2009 | Zebra Printer 140-751-00000
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Mar 11, 2009 | Zebra GK420 Thermal Printer
Zebra 170 xi labela are printing on top of each other
Don't forget to rate this.
You can download Zebra manulas from here. https://www.zebra.com/id/zebra/na/en/index/service_support.html here is a section of the calibration you require. Sorry it will not allow me to attach. i think issue with site usage.
Anyway press PAUSE to pause printer. Then find & press CALIBRATION, it will ask when you want to calibrate either at power up or after the print head is open & closed. I would select Power up since when you change lables out you should do so with printer off.
Good luck, post any questions to this & also rate it.
Feb 04, 2009 | Zebra 170Xi II Thermal Printer
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
