Question about Kenmore 42822 Front Load Washer
Small **** in the rubber molding inside the door; leaking.
M Kenmore washer, model 110. 42934 200, has a small **** in the rubber molding inside the door and the machine now leaks onto the floor in front of the machine, enough to mop up with a towel.
    President:
  • 1,430 Answers
You may need to replace the door seal. But first take some 100% pure silicone and push some in the hole and around the hole. Let this dry for 24 hours before using this should seal it up. If this does not work replace the door seal. Here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Posted on Jul 12, 2010
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.5 washer has developed mildew around the inside lip of the rubber surround. It has always had a terrible odor. I have used bleach to kill the mildew and now leave the door open. What do you...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Aug 02, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
We have a kenmore model 970c45072-00after the washer ia finished our clothes have a moldy smell
Oct 12, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
We have a Kenmore Elite Smartwash Quietpak9, It gave no problems for about 3 years. However, it has begun to leak. It doesn't leak every washer load, but mostly if there are towels in the load. We had...
You will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link epxlains how:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: The repairman was correct about leaving the door open to prevent mold and mildew. Due to the water tight seal of these doors it is important to leave the door open when not in use to prevent any residual water from becoming stagnant and allows the wash tub to air out. Also, you should always check and clean the area around the door. Small articles of clothing can get stuck in this area and begin to mildew as well. I have repaired this washer numerous times and personally own one. I have never had a problem with it in the 9 years I've had it, following this regiment.
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer smell
Apr 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Front loader washing machine stinks really bad
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Mar 30, 2009 | Kenmore HE2 Plus Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag HE 4t/ Kenmore Elite Smartwash Serial# CST0411376 MODEL# 11045088403 TYPE 199 712 CN/AP MY WASHER HAS A AWFUL ODOR INSIDE THE TUB. I HAVE CLEANED IT OUT WITH ALL KINDS OF CLEANERS TO TRY...
The following link provides guidance on how to maintain a front loader to keep the mold, mildew and odor away:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
These are recommendations provided by the manufacturer. Most important of all, keep the rubber bellow clean and clear of debris and make sure you leave the door slightly open when not in use. This will minimize the build up of any mold or mildew and allow the tub to air out. The odor typically comes from the the residual water that stays in the wash tub under the basket and small articles of clothing getting stuck in the rubber folds of the door bellow. (I once found 17 socks stuck in a customer's washer and they wondered why it smelled so bad). NOTE: It is NORMAL to have residual water in the wash tub. If you do not routinely use a hot water setting, run the washer on a sanitary cycle about once a week, or so, with a small amount of bleach to get rid of any bacteria. Since some users conserve and only wash in cold water, they do not bacteria get rid of any bacteria inside the wash tub. I personally own one of these washers and have never had any odor or mildew problems in 8 years by following this simple advice. If you have any further questions/concerns please let me know. I hope this helps you.
Aug 06, 2008 | Washing Machines
Kenmore 42822 Front Load Washer Logo
262 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
