Question about Bugaboo Frog - Black Stroller
Can i get a different colour hood? - Bugaboo Frog - Black Stroller
    Problem Solver:
  • 17 Answers
Yes there are different hoods for the frog, but I had one and bought the cameleon hood and seat covers as there are more colours and they fit it just as well
Posted on Jul 18, 2010
Light does not turn on when door is opened
Check the fusebox. It may be under the dashboard and/or under the hood, depending on the make & model of the vehicle. If your vehicle has glass tube fuses, you 'll notice one that's blackened in the centre or missing a piece of the wire. If it's the coloured plastic plug type, you are looking for one that's blackened in the centre or missing a piece of the metal in the centre. Either way:
1) it will look different from the rest so check carefully.
2) replace the fuse with one that has the same amperage as the burnt one.
a) Tube type: amperage number will be stamped on the shiny metal end.
b) Coloured plastic plug type: Besides using the colour codes, there is normally a number stamped on the side. If you can't read it, pull another fuse that has a similar colour and read the amperage.
More info at Wikipedia:
http://en.wikipedia.org/wiki/Fuse_(automotive)
Jul 16, 2013 | Cars & Trucks
Hi, I have the bugaboo frog stroller and the hood is very faded. Where can I get a new hood in black? Where can I get a silver sun hood?
The great thing about the Bugaboo it the availability of fabric sets in many different colours. You can buy online from www.bugaboo.com or google bugaboo in your local area to see if there is a supplier nearby.
Apr 18, 2011 | Bugaboo Frog - Black Stroller
Dont know what colour wiring is what
what do you mean by what colour wiring, different speaker headsets are different but basic wire colour if it helps red or brown is the live and blue or black is the neutral
Jan 30, 2011 | Car Audio & Video
Monitor changed to yellow colour.... what is the problem...?
Monitors mix the 3 "primary" colours, in various proportions, to produce all other colours.
Mix equal parts of all 3 colours, and you get WHITE.
Mix equal parts of only 2 colours, and you get YELLOW.
So, either:
1. your computer's video-card is not sending the 3rd colour;
2. your video-cable between the computer and the monitor is broken, and is not transmitting the 3rd colour;
3. your video-cable is not TIGHTLY connected at each end;
4. the electronics inside the monitor that SHOULD be producing the 3rd colour have failed.
Try connecting the monitor to a different computer, with the same video-cable. If it works correctly, your video-card is the problem.
Try connecting the monitor with a different video-cable, to see if replacing the cable fixes the problem.
Try connecting the monitor to a different computer, with a different video-cable. If it still is incorrect, then the monitor needs repair/replacement.
Jan 14, 2010 | Computers & Internet
My omnitech monitor is turning red when it wants to. no certain program just whenever
Colours on the screen are generated by "mixing" the 3 primary colours.
Of the primary colours is RED.
So, your LCD monitor is not receiving signals from your computer,
specifying the other two primary colours.
Check the data-cable between your computer and your monitor,
to ensure that the connections are tight at both ends.
Try a different data-cable.
Try your monitor on a different computer, with two different data-cables.
Try a different monitor on your computer.
It could be the video-card inside your computer is failing to "send" one or two of the primary colours.
Dec 31, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Left headlight out. how to fix and is it expensive?
Go under the hood and at the back of the headlamp there will be a push-in tab to push in and turn the bulb once you have the bulb out disconnect it from the wiring and take the bulb with you to the auto parts store to make sure you get the right one, about 5 - 8 dollars
Sep 02, 2009 | 2002 Toyota Highlander
Ap3800c will not print the colour it sees
So the quality is good, it's just not "exactly" like the screen? It never will be "exact". Depending on what you're describing, if the colour is off, it could need the drum(s) or Development unit(s) replaced to improve the quality; however, if your just talking about "matching" the screen colour, you could line up 100 different printers and you'd get 100 different outputs....it's not an exact science. Perhaps you're using a generic toner vs. the OEM brand, this would change your results too.
There are also 3 different printer "languages" (drivers) that the printer can print with: RPCS, PCL 5c, and Postscript 3. All of which will give slightly different print qualities. You may want to try installing a different driver than you're using, and you may prefer the output. Postscript 3 is the best in my opinion.
you can go to this link, select your OS, and download another driver:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p3800c/p3800cen.htm
I hope this helps.
Jun 05, 2009 | Ricoh Aficio AP3800C Laser Printer
Can i insert Two different coloureds Tag Rols in the Machine
If you put 2 rolls in, the labels will float around, since there is no way to keep each loose end in place.
Dec 23, 2008 | Zebra Z4Mplus Label Printer
Colour of the CDA CHIMNEY HOOD CPX7ss
the greyinsh blue color sounds like it still has the protective film on it that needs to be peeled off
Nov 26, 2008 | CDA CPK9 Stainless Steel Kitchen Hood
Bugaboo Frog - Black Stroller Logo
56 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
