Question about Samsung SyncMaster 953BW 19 inch Monitor
Our computer monitor is not coming up. how can we tell if the monitor is bad or something else is wrong?
  • 2,229 Answers
The most obvious way to tell is to swap out the monitor. If the new one works, the old one probably has a problem.
When you say "is not coming up" I assume you never see a thing on it. I would ask--do you hear the system beep once indicating that it has passed the POST? If not (and it always did), then I would suspect that since it hasn't passed its own diagnostics, you will never get a signal on the monitor.
I suggest disconnecting everything on the computer but the video, memory, and CPU (you can leave the mouse and keyboard connected).
If the system starts and displays something (most likely you will see a message indication no boot device), then you can assume you have a problem with a piece of the hardware.
Also, if you hear a series of beeps, they will help you troubleshoot.
Posted on Jul 12, 2010
My HP Monitor not displaying home computer
It could be your port to your computer that went bad. If you have a graphics card for you computer that could have gone bad. It also could be the monitor port. If the port went bad on either side it will usually say something on the screen about it not having a connection to the port.
It also could be the backlight for the monitor . Sometimes you can tell if the backlight went bad if you turn on the computer and shine a flashlight at the screen. If you see an image then the backlight is bad.
Feb 05, 2014 | HP L1710 LCD Monitor
Tahoe speedomoter abs break light on
More than likely you have a bad speed sensor on the transmission. If that goes bad it will make the needle bounce and give you false readings. The brake system sees this information and tells the computer something is wrong. The ABS system has monitors on all four wheels that measure wheel speed. Also at worst if your cluster is bad it will do the same thing. Start with the easiest less expensive part. There are tests you can run too but you will need a service manual. Good Luck.
Jul 21, 2012 | 2003 Chevrolet Tahoe
Got 1994 lexus both a battery hook it up and come to find out it was wrong battery . Now the car wont start did find some bad fuses i change it still wont start. Could be my promlem is the car compute
Wrong battery? What was wrong, voltage, size, terminal location. I am not familar with a Lexus does it have two batteries? If you hooked up two batteries and did something wrong, like hook them in series some way then you could have fried the computer. It is really hard to determine what problem you have. The bad fuses should tell you something what did they run? Please rate my answer.
Jan 27, 2012 | 1994 Lexus Es 300
When plugged into my PC, this monitor tells me "Out of Range."
It can be failure inside the monitor, but try it with another PC first.
The possibilty can be poor DC in the power supply which will be the first thing to check or failed EPROM which nothing you can do unless you have the way to reprogram it.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 30, 2010 | Neso Technology Pixo A700 17 in. Flat...
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
When I plug the monitor in the power light goes on yellow/brownish for a second then goes green for a second then shuts off, the monitor almost turns on, you can see something come on the screen, then the...
The problem can be bad power supply due to bad caps, bad inverter circuits, or bad lamps. Open it up and look for bad caps first then report back what you see so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
2004 jeep grand cherokee emission pump and hoses going bad which is causing the check engine light to come on. This wa told to me by a service center. Any potential truth to this?
it is possible, there are sensors that monitor the flow, and report accordingly to the PCM. if the emission pump is going bad, yes that will make the engine light come on, but it doesnt take long for those things to just go out at all. as far as it making the hoses go bad.....unless you have a ridiculous amount of pressure coming out (which you cant) then there is no way the hose could go bad, because the only things it could do would be to either get so hot, it melts, or the hose just blows out.
pump going bad? maybe....hose going bad because of the pump? no. use a diagnostic tester on the jeep and look at the trouble codes. because if you want to know whats wrong with the vehicle, ask it.
Sep 24, 2009 | 2004 Jeep Grand Cherokee
Green light is flashing and screen won't come on
Try another monitor on that computer and see if it boots up with video. If you still get the same problem then that means there is something wrong with the computer. If you get video this time then that means there is something wrong with the original monitor.
On your original monitor, make sure there is no bent pins and that the cable is connected properly.
At least this way you will know whether its the computer or monitor.
If its the computer thats the problem that at least go ahead and try to take out the memory and CPU and put them back into there respective slots and blow some air onto them so its not a spec of dust or dirt that is affecting the video.
Jul 17, 2009 | NEC MultiSync 1760NX 17" LCD Monitor
Fluttering LCD display
your monitor need to hardware reapair that is inverter and lamps or PWM power something wrong, you can not keep use that will become complex damage in hardware. it is not too hard to repair, you may find a computer company to fix it, please tell me where are you live.
Dec 27, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
I have an HP Pavilion 6535 computer using Windows 98SE. It was fine but now when I turn it on, the power comes on (has start up sounds and cd drive light) but there is no green light on near the start...
Listen for the number of beeps, when you turn on the pc. The beep code should be able to tell you what is wrong. It's possible that the power supply or the video card is bad.
Jun 21, 2008 | Computers & Internet
Samsung SyncMaster 953BW  19 inch Monitor Logo
330 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
