Question about Honda Car Audio & Video
I just install an a lanzar sdbt77dn radio on my 98 civic ..thr radio was working perfect for the first 3 hours then the speakers get silence like if somebody put mute on it ...what its wrong ???
  • Honda Master
  • 17,130 Answers
If this fault is occuring exactly every time then the time the fault occurs try to switch off and force cool with a fan. See it the fault condition changes . if so open up the set and let it run for the ttime to shut off, use an freeze it spray to the area getting hot and confrim if the fault changes. replace the concerned component, maybe the output drive or even the muting semiconductor. even it could be dettaching of solder joint on set getting warm. check with patience and caution. helpful I guess. Good day
Posted on Jul 13, 2010
I have just got my 1999 ford festiva back from the machanic and my radio was asking for a code, I put in the a couple of genernic codes that it could have been now it just says error, please help me, I...
Good Day Hannah!
You have to provide us the serial number of the radio. Look for it stick in the body frame of the radio.
Post it here and I will give you the radio code.
Thanks
Jul 20, 2011 | Metra Ltd 99 7899 01 Honda Civic Radio...
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
Could me and friend install a lanzar max 15" sub into a 2004 honda accord??
Technically speaking, you can install whatever you want into anything you want to install it into. I recommed you doing your research first, because a good amp and sub install job is more than just plugging stuff up. And if your not upgrading to an aftermarker HU, fuggedaboutit!
Feb 22, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
Parking brake bypass
Hi theres a code you have to put in i bought the code for mine on ebay here is a link to the one for lanzar on ebay make sure you double check the models it works on and yours is one of them>
http://cgi.ebay.com/Lanzar-automatic-video-Bypass-Hack-SDBT77DN-SDBT79NG-NV_W0QQitemZ230424999284QQcmdZViewItem
QQimsxZ20100117?IMSfp=TL100117224002r3200
Feb 05, 2010 | Lanzar INDASH 5.4" MONITOR DVD RECEIVER...
Rear door speakers not working in 98 tahoe
Your aftermarket radio may only have a 4 channel amplifier and will only be able to power four speakers. The only way of having the other speakers work would be to wire in an external amplifier
Dec 16, 2009 | Car Audio & Video
Arcam avr 300 keeps switching off intermitently, and the red standby light flashes.
I wonder if anyone can help explain what the likely problem will be with my Arcam AV300 amp. Whilst watching TV for no particular reason an extremely loud (what i can only describe as feedback) sound comes out of my B & W speakers for approximately 3 seconds, then silence as the Arcam switches off, I’m then unable to switch it back on for a period of time, (this varies between 5minutes to a few hours) when it eventually switches back on everything seems to be working perfectly. This has happened quite a number of times although it’s intermittent & occurring every 1 - 6 weeks.
Sep 18, 2009 | Audio Players & Recorders
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I need a diagram for the radio to install my new system please, just need to know what the wire colors are so i dont have to spend 2 hours of test to find them myself. I will find them but if you can let...
For 2008 Honda Civic, it would be as shown below. For all other years, you may want to try looking for your specific year here where the information was originally posted.
2008 Honda Civic Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: Violet
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Light Blue
Car Stereo Amplifier Location: Located in the front of the center console under the center of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green
Left Front Speaker Negative Wire (-): Pink
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Orange
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 31, 2008 | Honda Civic Cars & Trucks
No Power At All
I have the same problem with my sometimes. Sometimes it is working fine and when I turn the car back on, it won't go at all. On the back of the head unit, there is a reset button. Press the reset button then press the power button and it should work.
Oct 14, 2007 | Lanzar VBD1200 CD Player
Open Questions:
Car Audio & Video Logo
59 people viewed this question
Top Honda Car Audio & Video Experts
Chris Ward
Are you a Honda Car Audio and Video Expert? Answer questions, earn points and help others
