Question about Kenmore Dishwashers
My Kenmore dishwasher, purchased about 2 yrs ago does not was the dishes well. Why not?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve if it’s filling the dishwasher with water. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure. For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump. Low water fills are a very common trouble maker with today's dishwasher. Don’t think water temp. can be an issue with your 2years old dishwasher, still if you want to check then check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Dish washer leaks suds from the bottom of the door. When it was run with no soap it did not leak. I am using the same soap pods I have used since it's purchase, 1 1/2 yrs ago.
do not call that repairman again. check to see if gasket/seal is cracked and if the door can be adjusted to close tighter
Aug 06, 2015 | Maytag Dishwashers
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
We have a 17.5" Kenmore built in dishwasher. For the past 3 wks. It just doesn't clean the dishes. It's only 3 yrs. Old.
Check the in coming water flow to the machine.
If the striner is clogged clean it.
Refer user manual.
May 21, 2010 | Dishwashers
Dishes not getting clean. I use Jet Dry &
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 21, 2009 | Kenmore 24 in. 17039 Built-in Dishwasher
Kenmore 665 Dishwasher with a flaky heating element...
replace the heating element for the fix , somtimes they can be replaced without reomoving the unit.
Phil
Jun 10, 2009 | Dishwashers
Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Oct 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
20 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
