Question about Sewing Machines
I have a Nelco sewing machine. When I check it where the spool of thread goes. The rod is sruck down and i can't it up. I can't even put the spool of thread. what do I need todo?
  • 202 Answers
I have no idea what Nelco model you are talking about. Many have a spool pin that are just tapped in from the top. If yours is not thenm maybe its missing. Or maybe broken off. If its a type that you just pull up to use then maybe you can grab it with a pliers and pull. But if you can't grab it then take the top cover off and tap it out. Add some oil to it.
Posted on Jul 12, 2010
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
Jul 30, 2017 | Sewing Machines
Threading a nelco 5102
Machines generally thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread.
Jul 29, 2017 | Sewing Machines
Do you have experience with a Nelco Sierra 234F Serger? How is the quality of stitching, how easy is it to use and problem free is this machine? Are you still able to get parts for the machine?
As far as I am aware, Nelco hasn't been made for quite a few years--probably since sometime in the 1970's is my guess. I have an old Nelco sewing machine that is a tank of a machine and sews nearly anything I throw at it. But for finer work, I prefer my Bernina--probably because it has more stitch selections, sews a straighter stitch, and I know it better.
If you aren't able to have the machine demonstrated to you and you can test it to your satisfaction, I'd be reluctant (Actually, that goes for any used machine, not just Nelco!) The following may be helpful:
Thread Anybody heard of Nelco sewing machine Worth fixing up
Jan 25, 2017 | Sewing Machines
I have a Nelco model 217. No manual. Need to know how to thread.
This may be helpful even though not your model. Most machines of the same brand and similar models thread the same:
Be sure to RAISE the presser foot when threading the upper thread!
Oct 10, 2016 | Sewing Machines
How to thread the Nelco A2?
To find a user's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Search YouTube videos for threading tutorials:
Nelco Zigzag Sewing Machine Final Test Demonstration Video
VINTAGE ALL METAL NELCO MODEL 400 2 SEWING MACHINE
NIFTYTHRIFTYGIRL Vintage Nelco model 250 sewing machine
With your Nelco, be sure that you install the needle properly. Frequently, Nelco machines take the needle with the flat side facing toward the throat of the machine--not toward the read like most other machines. The upper thread will thread through the needle's eye from the left toward the right. They also are a left needle position machine--meaning, the standard position of the needle when sewing straight stitch is at the left side of the presser foot, not center like most other machines.
Nov 15, 2015 | Sewing Machines
Thread does not wound evenly on spool. Therefore when sewing it goes crazy with the thread on underside of fabric and then jams. What can I do to keep thread going on the spool evenly?
Your talking about the bobbin? If so your not threading it properly to feed the bobbin while winding. Sounds like you don't have the proper tension from proper threading.
Oct 28, 2014 | Simplicity Liberty SA1600 Mechanical...
Top thread keeps breaking, I've re-threaded to make sure it's right, wound and re-inserted a new bobbin, checked the needle to make sure it's not bent (as described in the manual) and put it back with flat...
Not sure if you noticed but if you thread a machine with the pressure foot down it will not thread correctly. There are two little things that sorta looks like symbols for the tension on most machines. (learned this when my viking 600e kept breaking thread and I put it in shop) If you thread the machine with the pressure foot down it closes the symbol things and the thread will break as you described. If you have completed that correctly check the spool of thread. You may have a burr on the thread spool that is catching the thread that too has happened to me.
Mar 30, 2017 | Brother LS2125i Sewing Machine
How to thread bicor vx 1005 sewing machine?
Most older machines start the thread from the spool on a spool holder then the thread goes through a tension dial, on to another tension holder inside the case. Then make sure the thread is going through a lever that goes up and down with the needle, through a thread holder near the needle.
Jul 14, 2009 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
182 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
