I have a new Memorex Model 2655 turntable cd recorder that does not record. Who should I contact?the display does not display "rec" and nothing is being recorded.
  • 4234 Answers
SOURCE: Turntable failure
The drive wheel has probably dried up and is just slipping. Also, any grease that was in there has probably turned more to glue. This unit will need some TLC and some time to get all of the old grease out. A re-lube as well as a new wheel (if still available) and you will be good to go!
Dan
Posted on Mar 26, 2008
SOURCE: Pioneer PL-300 Turntable plays records
No, I have a PL-300 and its directly driven by a DC motor. I have taken mine apart to clean once before and noticed some potentiometers on the bottom. (There are holes on the bottom of the plastic casing for easy access using a small flathead screwdriver) Those might be to adjust speed. They could also be for tone though... It might also be that the electronic quartz-based speed controller is broken. With these old things its never easy to tell whats wrong.
Posted on Jun 27, 2008
SOURCE: Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Posted on Sep 04, 2008
rehortonjr
  • 47 Answers
SOURCE: Turntable
Hi Harpwailer,
I was unable to locate an owner's manual for VSX-D412 on the Pioneer website. I did find a VSX-D411, which I believe is very similar. Since there are no turntable jacks, I would try any set of open analog (RCA cable, like the ones that come out of your turntable and are probably red and white) jacks. Just plug the red cable into the red input jack, and the white into the white. The only thing to be careful of is to make sure that you use the input jacks, since some components (like tape decks) have input and output jacks, so that you can record to/from them.
This will work fine assuming that the output from your turntable is strong enough. Many turntables are designed to go through a pre-amp circuit; if this is the case with yours, you'll know it since the output volume will be very low, even when turned up very high. If this is the case, you'll need to purchase a pre-amp to put in the circuit between your turntable and the receiver, or else buy another turntable that outputs at a higher level (they can still be had rather inexpensively, surprisingly enough!). Also, you'll probably have a ground wire coming out from your turntable as well. You'll need to hook it to a chassis screw on the amp to prevent an electrical hum from being picked up and output through your speakers.
I hope this helps, and good luck listening to your vinyl. If you deem it appropriate, I would appreciate a rating on the help I have provided. Thanks!
Bob
Posted on Oct 16, 2008
SOURCE: Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Posted on Apr 10, 2009
How to install turntable belt on Memorex Model 9290MMO Phono/CD Recorder with Cassette Player?
Most of these belt fitting are pretty much the same. So have a look at the video below
Jul 01, 2017 | Memorex Audio Players & Recorders
Anders Nicholson 2655MO Turntable Cassette CD Recorder 2655 MO Record Player manual is needed
Be sure you are asking about the correct Model number and name, ok?
Here is a link for someone selling that model on eBay.
Maybe you can contact her/him and ... who knows?
Sometimes a person just for no good reason at all, can help.
Who knows?
A
Dec 03, 2016 | Audio Players & Recorders
How to properly get this item to record?
search google with make and model of it then manual
Mar 08, 2015 | Audio Players & Recorders
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
New Memorex 9285MMO, loud hissing + ring dig on record
Probably the needle, I work on them and many needles are bad from new. They were put on wrong in the first place. Try taking the red part off and make sure there is a needle part and that its straight.
Jan 16, 2010 | Memorex MX212 Turntable
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
177 people viewed this question
 Grubhead
Grubhead
