Question about ViewSonic N3251w 32 in. LCD HDTV
How to unlock the main menu on a viewsonic tv. i can turn the volume up and the channel but not reach the main menu or use the numbers to turn the tv
  • ViewSonic Master
  • 5,475 Answers
The Menu Lock is enabled or disabled by pressing Vol+ and Vol- at the same time. (The two left most buttons on the front panel of the TV.)
I hope this helps.
(Check if the Menu button works on the TV (the third button from the left). I've had some remotes lose the menu button while power, channel up and down, and volume up and down work.)
Posted on Jul 12, 2010
How do I remove the child lock on my toshiba 42wp56p tv without the remote?
These are the general procedure to unlock a TV
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Check this method too. If neither of them help you, check this link.
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
Jan 05, 2013 | Televison & Video
My ViewSonic N2230w 22 in has a menu locked and it cant change to a different input and im trying to unlock it but i cant i need to get it to unlock
Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Nov 06, 2010 | ViewSonic N2230w 22 in. LCD TV
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
The main meun locked
Is this a viewsonic? I am told, to unlock the menu, try holding the up and down channel buttons in together. If all buttons are locked, try holding the up and down volume buttons in together. The buttons are under the screen. I am not sure if you can do this while the unit is powered up or do this while powering up. Try first while unit is powered and running. Each of the two processes should set the lock if not locked and should also unlock if locked.
May 25, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
May 10, 2010 | ViewSonic N2635w 26 in. LCD Television
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
After lightening zap
Call your insurance agency as this should be covered under your homeowners policy. The main driver board is made by JeanCo of Taiwan and is not replaceable and cannot be ordered as a part.
Good luck
Jul 12, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
Viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Oct 18, 2007 | ViewSonic N2751W 27 in. LCD Television
ViewSonic N3251w 32 in. LCD HDTV Logo
1,213 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
