Question about Hayward SAND FILTER, PRO SERIES
Sp 704 Which way should the handle be turned when putting the top on and replacing screws? Right now filter is towards the pressure gauge.
  • 760 Answers
Usually It makes no difference which way that handle goes. You didn't indicate what model valve you have. The handle turns 360 degrees. I usually lift the handle up so there is no spring tension on the valve plate, makes it much easier to get the srews in. Be sure your gasket is in proper position. Only turn valve with handle lifted, and with pump off.
Posted on Jul 12, 2010
How do you change the air filter on an echo cs310 chainsaw?
Place the saw on a work table so that you can look down on the saw. With the handle pointing towards your right hand looking down on the saw you will see screws that holds the top cover of the saw where the carburetor is. The filter is right on top of the carburetor. Replace in reverse order.
Sep 30, 2013 | Echo CS310 14" Bar Length Fully Assembled...
Hi I took the top off my sp 704 to check out the o ring it was good but when I try to put it back together I realized there are many way the top can be screwed on. Now I'm stuck can you help me?
There should be a flat edge on the side of one of the bolt holes on the lid. The valve body has a matching flat edge next to one of its bolt holes. Line the two up and you are in the correct position.
Aug 12, 2013 | Hayward SAND FILTER, PRO SERIES
How do I check my fuel pump pressure on a 2003 Jaguar S type
rent a fuel pressure gauge. look on top of fuel rail on top of intake.
screw on gauge try to start. look at gauge. find out how much fuel
pressure that your car should have. may need new pump or replace
fuel filter.
Jan 22, 2013 | Cars & Trucks
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
Dec 29, 2010 | 1999 Oldsmobile Alero
I jhave in my showers the Moen and One handle tub and shower faucet, model # T3132. When I turn it on in the showers, there is no hot water... in both it gives me only cold water... even if I turn the...
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Dec 21, 2010 | Moen & One Handle Tub & Shower Faucet
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
My cousin has the hayward sp714 filter. she lost the manuel for it. i need to bakwash and clean the filter. where can i find a owners guide for this product? the pool is to green and the pressure on the...
Instructions are on side of filter tank.Looks like a pro series top mount. Turn pump off.Press down valve handle and turn to backwash. Start pump. When water runs clear , rinse and return to filter. The pressure gauge is defective! Replace. Superchlorinate pool.
Aug 16, 2009 | Hayward SAND FILTER, PRO SERIES
Just installed a Moen shower fixture, & the knob for the shower head doesn't send water to the shower head-- I don't get it!
I just installed one this weekend. Make sure that the cartridge has the embossed "HC" at the top (for Hot on left, Cold on right) when you slide it back in. Also, before putting the handle on turn the cartridge shaft so that the completely flat part is toward the top and the side with the small notch at the end is toward the bottom.
Jul 26, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Air screw setting
Remove plug on left and install low pressure air gauge. Adjust right screw to 3.4 psi on the gauge. See web site www.Desatech.com Manuals with parts breakdown are available on line.
Apr 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Hayward SAND FILTER, PRO SERIES Logo
232 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
