Hi --- I have an Everstar MPK 10CR-1 unit and it no longer drips H2O into the water bucket on the side. Is something wrong? It is kind of cooling the room but I don't know where is the condensation collecting? Should I worry? Thanks you
  • 39 Answers
Have you tried running weed eater line up the drain hole to clear the possible blockage. I know this happens on the back drain as well when you drain in the bucket.
Posted on Aug 21, 2010
  • coolfelix Aug 25, 2010
    One more thing...when you put the weed eater line into the back top drain hole...you go in about 1/2-3/4 of an inch then the weed line needs to go vertical since the actual drip water comes down then sideways out. You can get a better idea by taking the cover off the A/C cord on the back with a phillips screwdriver. Then look in and sideways and you will see what I'm talking about.
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
My Everstar portable air conditioner model# MPK-10CR-1 will not drain into the bucket that comes with it. It is draining into the tray at the bottom of the unit then the unit turns off when the tray is...
Simple I believe...just run a weed eater line up the whole in the back where you have the clear tube. You can take the little back door off the power cord area to see inside where the water drips into the little tray before it goes down the hose tube. Water debris sometimes blocks the water from draining properely. The weedeateer line will clear the blockage and it will begin flowing again.
Jun 27, 2010 | Heating & Cooling
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
No water in bucket when AC tells me its full
remove the drain bucket and look inside. there should be a hose that runs from the evaperator to the drain bucket. if you can blow air through hose to see if it is clogged. or try to take casing off and pour a little bleach/water mixture down tube , it probably has some mold built up in it
Aug 18, 2009 | Danby DPAC8020 Air Conditioner
I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Jun 20, 2009 | Danby DPAC8020 Air Conditioner
Everstar air conditioner
My Everstar Portable Air Conditioner, Model# MPM-08CR-BB4 will not work. The only thing that works is the "P1" light. Please help!!!
Jun 09, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
473 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
