Question about Sanyo Televison & Video
Blck horizontal lines on Sanyo LCD TV
I have several black lines in one area starting on the left of the screen and fading as they go right. 46'' Sanyo LCD screen TV. Any advice on how I can repair or check a few things myself?
  • 87 Answers
SOURCE: Hitachi 62VS69 LCD Rear projection TV
It sound to me like a defective light engine. If so this is a very expensive repair if you set not under warranty or a service contract. This could have been damaged by a power surge.
Posted on Aug 15, 2007
CrazyLarry
  • 173 Answers
SOURCE: Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Posted on Jan 19, 2008
HDTV GURU
  • 261 Answers
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
Sanyo lcd tv picture has stopped working
Could be several things going on but the unit will need to be diagnosed to be sure. I would start with checking the t-con/LCD panel ribbon connections. Outside of that could be a defective t-con or LCD panel.
Oct 09, 2012 | Sanyo Televison & Video
Our Toshiba Regza LCD TV has developed a thin white vertical line down one side and a green horizontal line across the middle. The bottom half of the TV screen then comes and goes in muted and faded...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Aug 06, 2011 | Televison & Video
How do I fix a A black screen on the left side of
Hello; I do a lot of Sanyo repairs and have seen this problem several times. The left side may be black always or sometimes. In either case the LCD panel is bad. the part from Sanyo was last $1000.00. There seems to be some refirbs or knockoffs for $400. Time for a new set. John
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
We have a Sanyo 46" 1080P lcd tv that has been going black on the left side for about 2 months now ,it's like a black square on the left side , can you tell me what this is and what the cost would be to...
We've had the Sanyo 1080p Flat screen TV for about a year and a half and the right side of the TV is black when we turn it on and after about 45 minutes in brightens. Sometimes it still has lines flickering throught he uper right.
Solution?
Oct 05, 2010 | Sanyo Televison & Video
I have a Sanyo 46 inch flat screen hdtv purchased from walmart sept, 2009. Sure enough, months later my tv is having picture problems and getting worse. It started having portions of the screen darken,...
Call Sanyo for warrenty repair,tv is less than a year old.The problems,u discribing could be cause by the Tuner board,that the board,where the incomming broscasting signal cable plug into it.Worse cause,the LCD picture screen is shorting out and dying,than the tv is not worth repairing.The LCD screen panel are 90% of the tv,will cost the same as a new tv,if the LCD screen panel was to be replaced.Sorry,than the tv not worth as a whole tv any more,only as electronic's boards for parts,that it.
Aug 12, 2010 | Sanyo DP46848 LCD TV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Televison & Video Logo
283 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
