Question about Brinkmann 810-5301-6 All-in-One Grill / Smoker
Smoker Grill I just picked up a brickman smoker grill from a friend but it came without the instructions. I need to know which is the water pan and which is the pan for the coal. Then what is the best way to smoke my Salmon, ribs, chicken, etc?
  • 8 more comments
  • AGREENE May 03, 2008
    Brinkmann Sportsman Charcoal Smoker
  • hotshot25 May 11, 2008
    I to just got one from a friend and I dont hacve a clue on what to do minr has one blackpan and two grillgrates the bottom of the smoker has **** like cuts in it do i put the charcoil there
  • Anonymous Jun 09, 2008
    I just bought a brinkmann smoker at a yard sale, it came with no instructions.
  • Anonymous Jun 28, 2008
    Just got one at a garage sale and need to know how to set it up.
  • rbush330 Aug 23, 2008
    Just received a Brinkman 810-5301-6 smoker from a friend, but am not sure how to work it. Which is the water pan and which is the wood chip pan?
  • itzlinda Oct 04, 2008
    I just purchased a Smoke and Grill at a garage sale with no instruction manuel. Can anyone help me get one?
    email me at:
  • Anonymous Jan 06, 2009
  • wyms919 Mar 22, 2009
  • tbeloch Mar 25, 2009
    I just bought a brinkmann smoker/grill with out the instructions.can anyone help
  • Anonymous May 08, 2009
    picked up free brinkman smoke 'n' grill with no instruction manual
I just bought the same grill at a yard sale but it came with no instructions. did anyone find a solution for it or a website??? please email me at
thank you!!!
Posted on Jul 28, 2008
I found the manual I needed by going to the Brinkmann website. I needed a manual for the 810-5302 and I found it here:
Searching their site for different models is also possible by going here:
Posted on Nov 09, 2008
I need instructions for a viking gas grill...I have the smoker insert and need to know how to use the grill to smoke a round roast or tenderloin.
In order to use the smoker box, remove the last set of porcelain grids and flavor generator plate on the right hand side of the grill. Set the smoker box in theopening so that the front and rear tabs rest on the grill frame.
Always soak the chips in water prior to putting them into the box. Use the "HIGH" position to start the chips smoking, then reduce the heat to a lower level to prevent them from drying out and flaming. If the wood chips do flame up, add a small amount of water to extinguish the flame. Use
caution when adding water to a hot box to avoid steam burns. This tray may also be filled with water to produce steam.
Whether smoking or steaming, the grill should remain closed as much as possible to maximize the effect. During extended roasting periods, it is normal to add fresh wood chips and water to the box several times. Limit the amount of times the canopy is opened-each peek adds about 15 minutes to the cooking time.
Wait until Smoker Box totally cools before trying to remove it.
Enjoy you roast or tenderloin!
Feb 10, 2011 | Grilling
We have mislaid operating instructions. How do you work it?
This link should help you get a new set of operation manuals.
The basics of this unit is, load up the charcoal pan, fill the water tray up about 2/3 full, have some wood chips soaking overnight, pick your favorite recipe for a smoker (try smoker burgers!) umm and easy for the first try.
Get your charcoal going assuming not the electric model, place the meat on the grills, close lid, try to maintain about 225 temps, add your soaked chips on top of the coals, check you temps, add more charcoal when the temps start to drop on long cooks. You should be able to smoke some burgers in about an hour and a half. Low temps and slow cooking is the key.
I hope I have helped you out.
Jun 12, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Need a new firer box
You can order here.
I hope this helps.
Jun 05, 2010 | Brinkmann 805-2101 All-in-One Grill /...
Was given a brinkmann gourmet charcoal smoker/no manuals
Sure...the smoker top and middle lift off. There is a pan that goes over the charcoal pit. The pan is used to create moist heat. It will produce steam while you cook. I recommend flavoring whatever fluid you put in the pan with fruit, fruit juice, or frozen concentrate, or wine, mixed with water. You can put your initial batch of charcoal in the bottom, (pit) and fire it up just as you would any charcoal grill. once the coals are ready, you can put the pan over them, put the middle section in, (with whatever meat you prefer), then finally the top. During cooking, to produce a smoky flavor, you can put water soaked hickory or misquete chips with the charcoal, it has a door for access. You can also add charcoal as needed to maintain the desired heat level thru the door. Remember, it takes longer to prepare food on the smoker, the key is low heat and longer cooking times. For example, I usually cook a boston **** at about 185 degrees for up to 12 hours. Bon Appetite!
Oct 05, 2009 | Brinkmann Gourmet Charcoal Smoker/Grill...
Need instruction on how to season masterbuilt electric smoker
soak some hickory/ oak / mesquite chips any one of these will do, soak them in water for a couple of hours then put them in the pan and turn it on this will burn out any coating on the metal and flavor the grill for smoking leave it on for a good 2-3 hrs on med then on high mke sure you keep the chips replenished
Aug 23, 2009 | Grilling
How to make a smoker frpm a stndard grill
on a standard grill you build fire on one side of grill and put food on the other you can also put a pan ender food with water in it
Aug 15, 2009 | Grilling
Need instruction manual for the smoker h20 chargrill
all I need is the instructions on the smoker h20 chargrill thats all
Jul 01, 2008 | Char-Broil CharBroil 4637318 Grill
Lack of information
Feb 14, 2008 | Meco 5030 Smoker
Frustrated-please help !!!!!!!!!!!!!!
The problem is that you are not getting enough air into the smoker. What you need to do is drill some holes along the bottom of the smoker to let more air in. This is a notorious problem with that smoker
Jun 07, 2007 | Char-Broil Charcoal Water Smoker 4654301
Brinkmann 810-5301-6 All-in-One Grill / Smoker Logo
566 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
