Question about HP LaserJet 3600dn Printer
How do you adjust the paper tray for legal size?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
There is on the bottom tray a piece that can be moved it pushed till the end of the tray you have to push the piece first like a button then it will be released and you can push it till the end of the tray
Posted on Jul 12, 2010
Can the Brother DCP 7020 all in one printer print legal size paper?
Yes it can
  • Large paper capacity. Features a 250-sheet paper tray adjustable for letter or legal size paper. Plus, a single-sheet manual bypass for envelopes, labels or other types of media.
For your convenience Here is a link to the owners manual. Page 23 shows how to adjust the paper drawer to fit legal paper
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Jul 06, 2011 | Brother DCP-7020 All-In-One Laser Printer
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
How to print on legal size paper 8x14?
Hi
Right Click mouse to printer icon, choose printing preferences and choose paper size, choose the legal size.
Please let me know if you need more help
Mar 06, 2011 | HP Officejet 6500 Wireless All-in-One...
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
The printer is asking to load legal paper in Tray 1 but legal paper does not fit in Tray 1. How can I redirect it to mfp?
Paper up tp 14" long will fit in the paper tray.
Remove the paper tray fully from the printer.
You'll see a blue tab at the rear edge of the tray, this releases the adjustment of the length of the paper tray. Adjust to the size you need, and replace the paper tray.
NOTE when new (and in the box), the printer has tape on the paper cover (at the back of the printer), make sure this has been removed, as it will prevent the paper tray being pushed fully 'home' when adjusted to a large paper size.
If you print a lot on both A4 and Legal size, maybe it would be worth buying a second paper tray and leaving them set for the different sizes you use.
May 21, 2010 | Dell 3110cn Laser Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Change tray 1 paper size
You need to adjust the green paper size sensor in the back of the tray to letter. This is connected to sensors on the side of the tray. If you set it directly to Letter, then the printer will read the tray as letter paper.
Mar 13, 2009 | IBM Infoprint 1352 Laser Printer
Loading legal-size paper
:) it should load in the same tray as the letter size, you may need to adjust the tray adjustments to accomidate it, the paper setting are located in the print settings are you click print.
Oct 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
HP LaserJet 3600dn Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
