Question about Thermador PC366BS Stainless Steel Gas Cooktop
Burner shuts itself off after 10 0r s minutes of working normally
I have a 14 year old Thermador "Professional" stove with 6 gas burners + grill on the top and two (one large, one small) electric ovens below. I love this stove, it has been a totally reliable workhorse, and a cook A LOT.
Just recently one of the burners with the "LO" setting that turns the gas on and off at variable intervals has started quitting after about ten minutes. The electronic igniter starts firing, but the gas has shut off. After a while it will turn on again. Thermocouple? Other? Where? Help?
    President:
  • 1,891 Answers
This unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Posted on Jul 16, 2010
  • KC Chiu Apr 02, 2011
    I have a similar problem with my PSC366ZS which is only 5 years old. I would like to know how to replace the valve coil... which part I need to disassemble 1st ? Is there a service manual somewhere ?
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
I have a GE glass ~ gas cooktop that is 14 years old. One of the burners has a hard time lighting and just flickers. If I turn on another burner at the same time it will light and I have to turn and push...
I would say that after 14 years your stove could use a checkup/cleaning by a professional who will readjust the settings afterwards so it operates as it should. Don't try it yourself it's dangerous stuff gas.
Aug 04, 2009 | Cooktops
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Thermador PC366BS Stainless Steel Gas Cooktop Logo
338 people viewed this question
Top Thermador Cooktops Experts
Justin Duby
Justin Duby
jasbo
jasbo
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
