Question about Hayward Comfort Zone Electric Spa Heater 11kw
Heater wont stay on. HELP!
I have a 220V comfortzone XI 11.0 spa heater. When everything first kicks on, the heater stays on for 10 minutes or so getting the temperature to roughly 75-80 degrees. Then it shuts off. Even when the knob on the outside it turned fully to HOT, it wont turn back on for a good 10-15, this time only staying on for a minute or 2. I asked Hayward service guys about it, and they seem to be set on the fact the water has low pressure and this is causing it. Firstly, the filter is brand spanking new, and has no clogs. Second, the motor and pump are made for a pool. So there is no way there is no enough pressure. The jets even start to make your back hurt if you sit in front of them too long. Yet, Hayward is still set on the fact there is not enough pressure. What do I do?
  • Hayward Master
  • 10,291 Answers
Have the Hayward guys come out and prove to you that it is indeed low pressure and then get an estimate for repair costs. Assuming there is no warranty in effect, you might want to locate the heater manufacturer for guidance. They may have a website that may be of help.
Posted on Mar 20, 2017
  • 61 Answers
SOURCE: Hayward Spa Heater ignites for 2 seconds and shuts off.
Sounds like this is a flame sensor issue. It is not detecting the flame.
Posted on Apr 04, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
  • 139 Answers
SOURCE: Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
  • 139 Answers
SOURCE: Hayward Comfortzone pool heater pilot will stay
check for continuity at all control and safety components,i.e. press switch,high limits,thermostat,on/off switch and flame roll out switch
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Is there a remote thermostat control for the hayward comfortzone? if so where can i get one of these?
its on the main board if using a system 3 wire use pool spa and common see which wires go to which on sytem board put pool temp at desired temp then same with spa temp if jandy system go to pins 1 and 2 on long plug on top of board then go to pool and com at heater if jandy turn heater all the way up RS sysyem will govern heat
Apr 01, 2014 | Hayward Pool & Spa
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Older spa spa quip sq1500 need replacemnet control box model 2095bb5 and heater element
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jan 19, 2013 | Pool & Spa
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Hayward Comfortzone pool heater pilot will stay lit but main burner will not fire. If the TH terminals are jumpered it will, but it won't stay on.
Have you tried jumping the pressure switch, as well as the on/off switch. sounds like something in the safety circuit is open
Jun 10, 2009 | Hayward Comfort Zone Electric Spa Heater...
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Hayward Comfort Zone Electric Spa Heater 11kw Logo
833 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
