Question about Dell 3100cn Laser Printer
Changed drum and now does not print and makes a loud noise
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Make sure the toner is securley in the drum and that you ran the small piece across the the drum it is like a thin thread and at the end there should be a small piece that can be pulled through the thin thread that will clean the drum
Posted on Jul 12, 2010
Changed the ink cartridge and drum. now it makes this loud clicking noise during printing
hope you removed all the packing material from the drum before you installed it.
Apr 23, 2015 | Sharp AL-1655CS Digital Laser Copier...
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have an HL-5280DW it keeps making this loud ticking sound when I go to print and it said to replace the drum and I did and it continues to make the loud ticking/popping sound. What should I do?
Take out the drum and toner shut the door and power up, if the noise is still there during the power up short run, you probably need a new fuser. If the noise goes away with toner and drum removed you probably need a new toner. New ones, especially generic toners are too hard to turn and make that noise.
Jan 25, 2010 | Brother HL-5280DW Laser Printer
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Feb 18, 2009 | HP LaserJet 2840 Printer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
2 multi color lines loud vibration noise
If you have changed the OPC drum and cleaned the entire insides of the printer after taking out the toner cartidges and OPC drum.You need a tech to look at it. The fuser is probably messed up from loose toner.
Sep 04, 2007 | Minolta magicolor 2300W Laser Printer
Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Sep 04, 2007 | OKI C9500dxn Led Printer
Dell 3100cn Laser Printer Logo
75 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
