Question about Thermador Cooktops
My ECV-36 Themador cooktop two burners (right side) no longer work (can't regulate heat) and the cast iron is detiorating on the remaining two functioning plates. The vent itself still works but turns itself on and off intermittently and I can't adjust the speeed. I cannot afford a new one. I can buy a used EC-36 for $150. I don't know anything about installing or repairing. Does someone have an idea if it would be worth going down this road at all? My sister tells me to forget about the vent and just put the used EC-36 in it's place but I'd have to leave the vent there to cover the cutout. I may be able to afford a venting unit soon but this might be a stopgap.
SOURCE: dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Posted on Jul 07, 2008
SOURCE: Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Posted on Aug 13, 2008
SOURCE: downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Posted on Nov 30, 2008
  • 5603 Answers
SOURCE: How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Posted on Sep 14, 2009
SOURCE: Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Posted on Sep 29, 2009
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
I have a Fisher & Paykel CE901 36" electric
Sorry, I don't have a solution, but a similar problem. My CE901 is 6 years old. One of the regulators broke after one year. The repair (under warranty) caused an electric fire a couple of weeks later. After much complaining, I got a replacement cooktop from F&P. Now, 5 years later, one regulator stopped working, no longer turns on the element. (I guess that's better than no longer turning it off.) You are not alone. Seems like F&P is incapable of producing a simple regulator that works reliably.
Nov 28, 2010 | Fisher and Paykel 36 in. CE901 Electric...
Regulating the heat on Kenmore cooktop.
Bad control or infinite switch. replace the switch for that element and you will be good to go.
Jul 05, 2010 | Kenmore 36 in.43492 / 43494 / 43499...
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
121 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
