Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
MY ICEMAKER OVERFLOWED WITH WATER ALL OVER THE FLOOR--WHAT TO CHECK AND HOW TO REPAIR??
  • KitchenAid Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingMY ICEMAKER OVERFLOWED WITH WATER ALL OVER THE FLO - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
GE profile refrigerator pss266msra has a problem with the freezer. Replaced the thermistor and heater as suggested since I had ice buildup. Now icemaker is leaking water which is freezing into icicles -...
One of two things is happening.
1) the fill tube leading from outside the box into the icemaker may have ice buildup or is too close to the icemaker fill wall. Make sure there is a gap between fill tube and wall and check for ice in the tube.
2) wait for the icemaker to call for water and see how long is calls water for. It is only suppose to be 7.2 seconds. If it calls for water longer it can be overflowing. If overflowing than replace icemaker.
Usually there is ice buildup or something that the water is hitting and splashing everywhere.
If you have anymore questions or need more assistance please comment.
Aug 01, 2011 | GE Refrigerators
I have water on the floor in front of refrigerator. it only appears when the icemakeer water line is turned on. any suggestions
Possibly the filter needs replaced due to old seals . Turn the filter knob ccw to remove the filter . The filter is probably dripping water into the drain pan causing it to overflow when the water is turned on .
Sep 26, 2010 | Estate TS25AFXK Side by Side Refrigerator
Refrigerator is leaking on the ground
Assuming you are talking about water leaking, if it has a drip pan to catch condensation, it may be full and overflowing or missing a drip pan allowing water to fall to floor. If it has an icemaker and/or cold water dispensor, it could be a connection leak.
Oct 08, 2009 | Kenmore Refrigerators
Water is leaking in side the freeze
It's the pump for the icemaker/water dispenser. When it goes bad, it just starts pumping water into your icemaker until it overflows into your freezer. You simply have to replace the pump. It's happened to mine twice.
You can very easily replace the pump yourself in about 3 to 5 minutes, and the pump only costs about 48 dollars.
Here's a link to the cheapest place to buy the pump: http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=RS22AQXKQ&searchTerm=&RefineSearch=0
The first time I had this repaired, the repairman charged me over 300 dollars. I did it myself the last time. All I used was a pair of pliers.
Jan 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
Kenmore Coldspot 10650522100 - water not getting to icemaker
look and inspect closely why the water is not going down the ice tray. maybe the soft hose to lead the water down to the tray is kinked or broke.
check also if there are still ice in the tray, they could have not dropped yet that is why water is just overflowing on the tray.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
134 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
