Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Our kitchenaid superba isn't making ice or dispensing water. Is there a fuse or something simple that it could be? I don't have to call out a technician if it is.
  • 327 Answers
Hi, it has a defrost problem. Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer. Next most common would be the defrost timer. Third would be the defrost heater. Let me know if you want to try to test these parts. If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
1. Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator. (Part # WR51X442) Can be purchased from http://www3.sears.com/. It is $51.72 plus tax.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem (Part # WR50X0122) However the best thing to do is replace the heaters and defrost thermostat which is included in WR51X442. It is easy to install.
Follow these steps and this will solve your problem.
Thanks
Posted on Jul 12, 2010
How to replace kitchenaid superba light bulb
The light bulb on the water/ice dispenser on our Kitchenaid Superba side by side refrig needs replacement. Easy! Right?
However it is screwed in so tightly and the location is behind the panel is so small, it it very difficult to get a grip on it to unscrew it!
We,ve tried rubber gloves, WD-40 and an Exacto knife(w/ fuse turned off!) and still cannot get this very annoying light bulb out!!
Does anyone have any ideas or can we remove panel it hides behind to get to it!!!???
Thanks for any info on this should be simple issue!!
Susan M
Jan 15, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Problem with kitchen aid superb side by side refrigerator - ice will not dispense. It makes ice, and the water works just fine. Is there are part that I can by to replace the door insert all together?
This is the auger, the unit that dispenses the ice. Check to make sure that the power to the unit, usually plugs into a port in the freezer, isn't dislodged or loose, If that doesn't fix the problem, you can call local part sellers, you can find one on www.whitepages.com, and see how much for a new or reconditioned one.
Hope this helps
Joe
Aug 29, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Noisy ice dispenser door
It could be something as simple as you might need to manually defrost your ice maker. There is a auger that moves the ice forward that could be iced up. Try that first.
Jun 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
175 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
