Your lid switch is fine. Because it will pump out and wash. That must be a broken drive coupling. More here Plenty more here
Rate it or hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. To watch a free video on how to check and replace this part go to http://appliancehelponline.com/topdirectdrivevideo.html this will walk you thru this. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
SOURCE: Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
SOURCE: -no agitation
Hello
Welcome to Fixya
My name is Huum,
All functions operate normally except the machine will not agitate.
The agitator is driven
by a couple of different methods. The first is the agitator is splined
and slips onto the matching splines of the agitator shaft from the
transmission. The second is the use of a bell coupling which is splined
to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch
the agitator shaft to see if it is working properly. This wil require a
small load setting of water and the machine set to run. If the agitator
shaft is working properly, it is either the splines on the agitator or
the bell coupling that is defective. If the agitator shaft does not
work properly, the problem is in the transmission.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: Washer won't drain or spin out the water
i pulled the motor out od the bottom and pulled a baby sock out of the gear in the balis tank
