Question about Minolta magicolor 2200 DeskLaser Printer
Minolta 2200 calibrating problem
My printer had low cyan toner but dosent say that now. Just has the calibrating loop that it is stuck in. How do I reset it? I don't have the software that comes with it.Thanks for any assistance.
  • 81 Answers
If have downloaded your printer driver. uncompress your driver and look for setup filename. use setup to install the driver and it will also install the utility software for the printer.
Posted on Oct 06, 2008
Trouble code c2551 on konina minolta bizhub c454e
c2551 come when Cyan low toner in Cyan Developing Unit.
Try to reset by opening and closing front door.
and check toner supply-hopper
if not still ok then replace Cyan Developing Unit.
Nov 30, 2016 | Konica Minolta bizhub Office Equipment &...
HP CP3505n only cyan is very light on paper, cartridge is 3/4 full and it was good before paper jam
Hi delumo
Thanks for trusting Fixya for solutions
It is due to bad color calibration. Do try to perform manual calibration option from the printer menu to solve the issue. And before the take the CYAN cartridge our the printer and shake it a little so that the toner powder gets spread equally. And then perform the calibrations.
May 05, 2014 | HP Office Equipment & Supplies
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Ricoh Aficio CL2000N Laser Printer
HP Color LaserJet 4500N Toner Cartridge Stuck
Hi, i have the same printer and regularly get this problem. Open the top cover and rotate the cartrige that is on top slightly backwards towards the back of the printer. Once you turn the printer on again this usually solves the problem
Nov 13, 2008 | HP Color LaserJet 4500n Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
Calibrating fw 412050g123d0
does it indicate low toner? fw:412050g123d0 is the firmware version.
try to reset it.
Dec 10, 2007 | Minolta magicolor 2200 DeskLaser Printer
Minolta magicolor 2200 DeskLaser Printer Logo
351 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
