Question about Xerox Phaser 7760/YDX Laser Printer
Got error when print to Xerox phaser color printer 7760. Knew was good files tried from acrobat (pdf) indesign and quark got the same error from different pcs and macs: This pdf file has an error and cannot be printed. however all these files can be printed correctly from any other printer. installed driver from cd comes with the printer and the xerox online site as well. thanks!
    President:
  • 2,072 Answers
If the printer does not have a hard drive. Pdf will be hard to print.
Second, Are you using a PS driver or PCL? If PCL change to PS.
Here are some direct printing setups also.
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
Posted on Jul 13, 2010
Cannot print in color to a xerox phaser 7760 dn ps
If you print a test page from the printers control panel, does it print in color? (Like the supplies page)
Mar 24, 2014 | Xerox Phaser Office Equipment & Supplies
Papaer empty
it first detects that no paper in the selected paper supply and it cause an error to your computer memory and printer memory so you must reset the job to clear the error on its memory to the two units.
May 15, 2010 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
Jun 10, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox 7760 GX squishing print jobs vertically
you need a snippet {software patch installed}call .xerox support
Mar 13, 2009 | Xerox Phaser 7750GX Laser Printer
7760DN is printing pages of jibberish
You can go to Xerox.com and try some different drivers. But most likely you have an issue with the specific software printing to the machine. I would see if a different driver helps, then call 1-800-835-6100 and talk to second level support .
You can also go to the xerox site and click support and drivers, enter 7760 in the search field, then go to the support page, type in Quark in the search field there and see if they have any information there.
Jan 28, 2009 | Xerox Phaser 7760DN Laser Printer
Offending command: get
Offending Command: get. Graphics format in pdf document is not handled:
If you are the creator/owner of pdf document then edit pdf document and check Imported graphics.
If not try updating acrobat reader to last version.
If none of the above works, then only solution is to print document from different computer/printer.
regards
Mar 12, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 7760/YDX Laser Printer Logo
379 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
