Question about Dualit CTS4E 4-Slice Toaster
The time clock does not always turn off resulting in the toast be
The clock makes the noise but does not move thus causing the toast to burn
    Problem Solver:
  • 14 Answers
Probably needs a New timer best price I have found, with instructions http://www.mcssl.com/store/electra-craft/catalog/product/522920765afa4d168f30d465bed95c1a
Posted on Jul 15, 2010
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Uneven rotation of basket, bang noise, water spills
if you can open the door,grab the inner basket at 9 and 3 o'clock and see if you can move it sideways,then again at 6 and 12 o'clock and move it up and down,if you can do this,then the drum spider trunnion is broken in behind the tub and the tub is loose which will require a new tub and trunnion as they are not sold separately at about $400.00
Oct 22, 2012 | Whirlpool GHW9400 Duet Washer
I have a kenwood amp. The fan is running but no power is running my subs. I have changed all fuses and checked all connections but it still will not turn on how do i solve thus problem?
Check your subs. Make sure they are not toast. Sounds like the amp is on, but it seems like its not working, when it could be your subs burned up. Push on them, and if they don't move and are rock hard you cooked your subs.
Other things it could be.
  • Bad RCA cables.
  • Incorrectly wired subs.
  • Amp in protection mode(must disconnect power to amp for a minute to reset)
Aug 08, 2011 | Kenwood Car Audio & Video
Noise some times and fans dont work some times
99 out of a hundred times - when the fan motor on a window unit 'makes noise and works intermittedly,' you have a bad fan motor which will require replacing.
Sounds as if the fan motor's bearings are making noise - which - would account for the fan working only part time. The reason being is that the 'bearing noise' you are hearing - is a result of the bearings being wore out - thus it causes the fan motor to heat up and 'go off' - on the internal overload' which is built into the fan motor.
Like I said above - most commonly the 'fix' is to replace the motor.
Jun 09, 2011 | Frigidaire FAC106P1A Thru-Wall/Window Air...
I have a 2004 honda ody. First I was having left turn signal problems, sometimes it works when the headlights are on and sometimes it doesn't. Last night all the dashboard lights went out. I don't have...
First, let me advise you that a blown fuse is never the cause of an electrical problem. They are allways the result of the problem. A blown fuse is allways the result of an electrical overload that could potentially burn your vehicle to the ground. Replacing a fuse without finding out and correcting WHY the fuse was blown is a total waste of time and effort and will only result in another fuse having to give up its life to keep your car from toasting itself.
The problem you are describing sounds a lot like a mutifunction switch shorting out. It needs to be checked for this as well as the connector to the multifunction switch because the connectors usually get burned. This could also be a simple flasher module problem.
Dec 16, 2010 | 2004 Honda Odyssey
My unit is interrupting the startup and burning the 220 breaker, any thougths?
I would say it sounds like the compressor shorted or one of the three wires is/are grounding out. This should trip the breaker not melt/burn it. The other option is that the condenser fan is not coming on thus causing the compressor to overload and toasting the breaker. I am assuming that you have a 30/40 amp breaker. Once you install a new breaker the turn the unit on and see if the outside fan is working and is the compressor is running. Hope this helps tim
Aug 28, 2010 | Ruud Central System Air Conditioner
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Dualit CTS4E 4-Slice Toaster Logo
176 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
