Question about Dryers
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
Http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Posted on Jul 12, 2010
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Creda simplicity condensor dryer model no T622CW.Problem, dryer continues to turn when door is opened.Which part(inc part No) do I require?
You need to replace the door interlock or switch as it is better known.
You could spray inside the switch opening with WD40, before replacing switch, as it could be just sticking.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Dryers
Door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Apr 04, 2009 | Creda W100FW Front Load Washer
Fluff escaping from my Creda Simplicity Dryer T522VW
You don't say how much fluff is escaping, but some things to check are -
1) That the lint screen is fully seated into the top of the dryer vent
2) All the way to where it discharges the house, is clean and free of restriction
3) Check that the dryer door gasket and lint screen cover gasket's are in good condition and do not allow air leakage.
Make certain the flex duct leading from the back of the dryer is connected tightly to the dryer and the vent duct, and make sure the flex duct is not split or broken.
Jan 22, 2009 | Dryers
Washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Feb 27, 2008 | Creda W100FW Front Load Washer
Creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Nov 30, 2007 | Creda W100FW Front Load Washer
Dryers Logo
336 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
