Question about Datamax I-4308 Thermal Label Printer
DMX-I-4308. Hit print and the printer shuts down. Let if sit for a while, turn back on and can print again. But after a while, hit print and printer just shuts down again. No error messages...just turns itself off. thanks, Scott
  • Bill Franke Mar 28, 2012
    I am a full time electronics tech and our business owns a DMX-M-4306. We had the same problem. The printer would shut down on its own after awhile. We suspected it was a thermal problem as it would work better with the case off. LEDs go bad with time and heat and the switch-mode power supply has two of them in the form of optoisolators (TCDT1102). We replaced these (Mouser electronics has them) and the problem went away. Hope this helps.
  • 3,866 Answers
I would suspect something inside is getting hot thus overheating then causing the printer to shut down. We are talking about thermal here just keep in mind when these get to hot they shut down. So i would have it repaired its more then likely a sensor that is causing it to shut off.
let us know
please do click the accept button for my efforts.
Posted on Jul 12, 2010
Reversing Labels before Printing
It's called "Present Distance" and it can be set to "0" in the printer's control panel. Look under Print Control.
Jan 21, 2014 | Datamax Office Equipment & Supplies
Ink system failure
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
Tip
HP LaserJet 4250n: How to print a config page
Almost all modern printers have the ability to print out a configuration page -- a pre-formatted page with all sorts of information about the printer and its status. The items found on a config page will vary from printer to printer, but typically they include the network address and other network settings, a list of optional features that have been installed, the printer's page count (number of pages printed), and possibly the current ink levels. For color printers, the page count is typically broken up into black and white (or monochrome) and color.
To print a config page on an HP LaserJet 4250n, follow these steps:
A. If the printer is not already powered on and warmed up, turn it on now. Then hit the Menu button (the gray button to the left of the display screen.)
B. Using the down arrow button, scroll down once to Information and hit the Select button (the green button with the check mark on it).
C. Hit the down arrow button again to scroll down to Print Configuration and hit the Select button again.
The config page -- which might actually be two pages if you have a JetDirect print server -- will print out immediately if the machine was at the Ready screen when you started, or it will print out as soon as the printer warms up if you just turned it on. The display screen will automatically return to Ready.
If the printer is currently in an alert state -- because of a paper jam, empty ink cartridge, lack of paper, or other problem -- it won't be able to print the configuration page. Remedy the problem shown on the display screen and try again.
on Jun 17, 2010 | HP LaserJet 4250n Printer
How to I shut off the audio voice commands - for example "printing started" "printing complete"?
Go to Control Panel > Printers & Faxes > right-click on the Lexmark printer print object > Properties > Advanced > Printing Defaults > in the Lexmark Printing Preferences windows, go to Advanced tab > More options > select Never show the Printing Status window or Printivity Tips. > Hit Ok > Click Ok again > Hit Apply > Hit Ok again.
May 19, 2011 | Lexmark Z816 InkJet Printer
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Jun 05, 2010 | Datamax I-4308 Thermal Label Printer
We can not use our print DATAMAX DMX M CLASS
What type of stock are you using? Gapped, continuous, or reflective mark?
If you are using a standard gapped stock, and the stock is loaded in the printer and ready, press the feed button until 3-6 labels are passed beneath the media sensor.
If you are using reflective (eyemarked stock) go in the the media settings. Change the sensor type to reflective.
Make sure that the eyemark is presented to the sensot at the small white strip on the sensor. Do not move the sensor to a place where the sensor will see anything but the mark.
Dec 31, 2009 | Datamax I-4308 Thermal Label Printer
Printer says out of paper when the tray is loaded
1. Shut the printer down
2. disconnect the power cable and network cable if you have one
3. wait 5 minutes
4. put the cords back in
5. power the printer back up
Good Luck !!!!!
Jul 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Jun 22, 2009 | HP PSC 1350v All-In-One InkJet Printer
I can not print anything from the Internet with my HP psc 750
Try this.
Goto-->Start-->Type cmd & Hit Enter
Now on the cmd prompt type net stop spooler & hit enter
After the message "The Print Spooler service was stopped successfully"
Type net start spooler & hit enter
after this process try to print again..sure it will work.
Again same issue then i would suggest you to power off your printer for a min & power it on back.
I am sure it should work.
Mar 13, 2009 | HP PSC 750 All-In-One InkJet Printer
Datamax I-4308 Thermal Label Printer Logo
80 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
