Question about GE Nautilus 24" Built-in Dishwasher
Need part# of door seal gasket for GE Nautilus GSD4100J00BB
Looks like the sealing gasket on the door of the dishwasher is torn. So, I am looking to purchase a replacement one.
1) Can you please provide the p/n and a website where it can be ordered?
2) Also, is there a drawing/picture that I can reference to ensure that I am buying the correct one?
Thank you.
Yan
    President:
  • 1,430 Answers
Enter your model # at www.appliancehelponline.com this is the part # AP3798079
The part is in stock and all parts come with installation instructions.
Posted on Jul 12, 2010
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Soap and water coming out the front of the dishwasher
I would think that the gasket is not doing the job, can you pull the gasket together to decrease the gap. If not then try another gasket if it's not on warrentee
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher seal
What model #...you will need this to get the exact part..
You can find them on a label on the tub wall just inside the door.
Here is a GE gasket part number from a site I will provide a link to
Item #
1088473
Here is a link...for a great place I have used many times in my 35+years in the industry...(many times since the site has been up :-)...)
http://www.repairclinic.com/GE-Dishwasher-Parts?s=a9b3&n=2
This should get you on the right track....good luck and good day...thanks for rating my effort...The Fang.
Mar 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaking
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Jan 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaks when jet dry rinse is added everytime.
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Nov 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
How to change a GE dishwasher door seal
I had the same exact problem TWICE....second time I'm replacing the dishwasher. There are two rubber boots at the bottom of the door that just sit and the door seal is supposed to seat into these rubber boots but if you take out the boot you will see that it is misshapen and therefore leaking. These boots cost about $10 dollars apiece from GE on line. I replaced them once and same problem. I was going to replace the gasket that runs around the door but it costs $50 and I'm not SURE it will fix the problem. I'm on my way right now to buy a new dishwasher....they're not that expensive compared to pumping money into something that you don't know if it will work. Good Luck.
Nov 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
494 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
