Question about Canon imagePROGRAF iPF610 - large-format - color - ink-jet Printer
Printer cannot be contacted over the network, and will not print after a new DLink router installed
I have a printer which is the canon imageRUNNER 2318 and i have to put it on the local area network.after signing the ip address to the printer still i can't print.the arrangement is like this there is a...
What you might want to do is reset the printer to its factory settings, which would include DHCP for the IP Address (your router will assign).
Then re-run the install of the FULL Printer software (drivers plus network scanner, etc.). With the printer on the network, when you run the reinstall it will scan the network looking for the printer and, in most cases find it. That way you know you have a working network and a working set of drivers.
If you then decide to set a static IP on the printer you can go into the Printer Properties on your PC and change the IP. If that fouls you up, you know how to recover.
Feb 25, 2018 | Canon Office Equipment & Supplies
How do i add the printer the dlink dir 628 router
The DIR-628 does support a USB printer. You need to download the appropriate shareport version from dlink http://www.dlink.ca/products/?pid=DIR-628&tab=3.firmware
If the printer drivers are already installed on your PC you should be ready to go.
Sep 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I just just changed my Linksys Router for a new DLink router model DIR 628, everything else on my network is working fine as before however I cannot print to the HP 5200 tn printer. The help line at DLink...
The Manual with the printer should tell you how to set the IP. Your best course of action however would be to set your router to broadcast DHCP and set the printer to obtain IP automatically from teh router. This will resolve any future issues you may have changing the router out.
Aug 23, 2009 | Computers & Internet
Have a linksys router tring to get adlink print
Did the dlink print server come with an installation disk? If so, you probably need to run that. It will help you set up a virtual printer port that you can then choose when adding a printer. For seting up two printers, you'll have 2 different virtual printer ports. For example SCB77031_P1 and SCB77031_P2.
If you need more help, please let me know what model linksys router and dlink print server
Aug 23, 2009 | Linksys Computers & Internet
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Networking a Panasonic DP-2330 Multifunction printer/copier.
Hello the MAC address is #28 located on the General Setting list under Function menu. Print it off. The key opp code is ussally 0000. Good luck I am in the same boat.
Feb 17, 2008 | Panasonic Workio DP-2330 Printer
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
Canon imagePROGRAF iPF610 - large-format - color - ink-jet Printer Logo
1,231 people viewed this question
Clive
Clive
old marine
old marine
