Question about HP Pavilion dv4000 Notebook
Projector Picture Size
When I hit fn+f4 once, i get a great projected image that is just the right size, but I can't see the image on my computer. When I hit fn+f4 a second time, I can see the images on my computer, but the image project is now way too big. For some reason, the first time it is set at 1024x768, but the second time it reads as 768x578.
  • 2 more comments
  • HPNeedHelp Apr 20, 2008
    Thanks for your quick reply. However, I don' t understand about the extended or clone mode. Can you please explain exactly how I set this up?
    Unfortunately, this didn't change anything. I am still missing most of the pic from the projector. Both display 1 and 2 are set to 1280 x 800.
    When I was setting the setting the resolution, and I click "identify," no matter if I am on display 1 or display 2, I get a "1". Does this mean that I am not able to set display 2? Or is there some other problems.
    Thanks for all of your help...
    Thank you, thank you, thank you...it works
  • Anonymous Mar 31, 2014
    I need to reduce the projected image of a PowerPoint in 2010 because the projector does not have a satisfactory zoom facility.
    Scholar:
  • 144 Answers
It also depends on the Graphic caru d that you have in the notebook, as ATI, Nvidia and intel all handel the output slightly differently. After you project image out to projecter,you have option to set,it is in display setting , under resolution .You can choose to clone or run two independent displays, ie the notebook at its natural 15.4" display, and then the projector at what ever its natural res is. To get this to work properly you need to do this in extended mode, not clone mode. This has advantages and disadvantages depending on your view point
Hope this helps a bit
bye.Takecare.
Posted on Apr 20, 2008
  • Technocom
    Technocom Apr 20, 2008
    1.Connect and output the picture to your projector by pressing twice (Fn+F4), you should have picture on your laptop and projector
    2.click start button and go up to setting and get onto control panel
    3.click on Display in control panel
    4.go up to last tap (Settings) on display properties window
    5.Under display heading you can select display1 and display2
    *** Display 1 mean your laptop,display 2 stand for any external monitor(your projector)
    6.here you can set resolution of each display
    7.to use extended mode select display 2 and below you can check "extend my window destop onto this monitor"
    ** this mean you can drag what you see on Dispaly 1 to Display2.Your display2 is an extended area of your display 1
    8.If you don't check "extend my window...."here on monitor 2 then you're in clone mode,everthing will be the same for display 1 and 2.
    so if you want both to be the same try to adjust 2,but this will cos display 1 to reduce down resolution also, due to display card memory ability to support display.
    Bye,goodluck.
  • Technocom
    OK, I think first you should check your projector specification that how high does it support for resolution and try to set to that
    highest specification but should not exceed that resolution.
    After that if you're still not able to select the monitor then its
    display card restriction.Try to click Advance button under resolution setting and see that you've anymore to set here.Sometime the company they have extra menu here.
    Bye,goodluck and takecare
All projecters doees not recognise my laptop
this is not a projector problem. For this you should use the hotkey on your laptop once connected to the projector to switch your display to the projector. On most computers this is fn( lower left of keyboard) + f4 or alt f4. The longer way to do this is to go to control panel and select display and select display number 2
Dec 11, 2013 | Fujitsu Siemens Computers & Internet
When using F4 on my Compaq Presario laptop, pictures of my computer screen and project shows, what am I doing wrong?
if your "F" function keys are a second function of the keys they are on there will be a key, usally located in the area of the lower left corner of your keyboard. If the "F" functions are in color, so will the key that activates them. The idea is that you hold down the Fn key while striking the selected "F" key
Jan 05, 2018 | Compaq Computers & Internet
My hp probook 4510 not connecting to projector, was working before
CONECT AND CLICK( FN )AND (F4) KEYS FN ARE INSIDE OF A SQUARE THE F4 MAY BE IS THE KEY TO ACTIVATE PROJECTOR YOU HAVE TO SEE THE IMAGE LIKE A SCREEN A SQUARE AND TWO LINES ONE ON RIGHT SIDE AND ONE ON LEFT SIDE
Nov 25, 2010 | HP Computers & Internet
Tried projector no work
Connect your projector to your laptop using a VGA cable. Now turn ON your projector and your laptop.
To make your screen projected, look at your function keys (F1 to F12). Look for the icon which looks like a laptop LCD and a TV. It should appear like LCD icon/TV icon. In some model it is in F4 while F3 in Lenovo. Example, you found the icon in F4, just press and hold down the FN key and press F4 to send your desktop image to the projector. This combination is called the "dual monitor" setup which in your case, the second monitor is a digital projector.
Jun 23, 2010 | Everex StepNote NC1500 Notebook
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
Projecting on a screen
Press Fn+F9 or the F key that has this drawning:
Cheers
Jun 23, 2009 | Toshiba Satellite P25-S507 Notebook
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
Unable to connect sanyo projector to sony laptop error is no signal Thanks in advance shaik
You need to use the Fn key on your computer to change the signal so your monitor signal projects through the projector.
On my computer I use the Fn key and F4 and it will then send the signal through the computer to the projector.
Aug 14, 2008 | Office Equipment & Supplies
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
