Question about RCA RCR311B Remote Control
I cant get my remote control to turn my tv to video 1 or 2
My remote is not getting any response from the tv set. I took out the batteries and reset them in the remote.
Posted on Aug 02, 2010
Cant get my ilo tv to change the tv input with out tv remote
No. To select inputs, you must have its remote control.
Sep 28, 2012 | iLO Televison & Video
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this helps.
Jul 13, 2010 | RCA Universal Remote Control
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
My DVD remote does not work on tv
1) replace batteries by new ones, clean contact from oxide, and see if the wires is open or brokern and repair
2) chek if the codes is o.k
3) was working before?
4) did rmote control was slip to the floor?
5) go to esupport.sony.com and download the code for Free and test the remote again.
Otherwise the remote is faulty. I f the TV is turn on, and changing channels.
sincerely. G-d bless you.
ernesto cuadra
managua, nicaragua
Apr 16, 2009 | Sony RMT-D166P Remote Control
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Remote
the intruction are at the back of the battery .
1 turn on tv
2 press and hold Code Search untill all device bottons light( they will all turn green)
3 press tv button. tv botton will stay on
4 press power repeatedly untill tv turns off
5 press enter and you are all set
repeat 1-5 for vcr , ect
Apr 01, 2008 | RCA RCR350 Remote Control
Rcr311w remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 13, 2008 | Universal Remote Control DIRECTV Universal...
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
RCA RCR311B Remote Control Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
