Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
AC unit goes on and off every 3 minutes
I just recently replaced my old mercury thermostat with a new Honeywell RTH230B programmable one. The unit cycles too often. I'm using the cooling unit right now and the tempature only comes up one degree before the unit kicks on again. Is there any way to program it to wait at least 3 degrees before it comes back on again?
    Problem Solver:
  • 9 Answers
It should not be doing that. The thermostat is pre-programed for only 4 cooling cycles per hour. You can change the program by :
�� To access the configuration menu, press both up/down buttons
simultaneously for 3 seconds.
�� To go to the next parameter (menu item), briefly press both
buttons simultaneously.
�� To modify a parameter, press one of the buttons.
�� Repeat steps 2 and 3 if necessary.
�� Press both buttons simultaneously for 3 seconds to exit
the configuration menu.
You are looking fpr parameter CPH this number tells the unit how many time per hour to come on lower it to leghten the time betwen cycles.
Posted on Jul 12, 2010
Outdoor AC unit runs for about 2 minutes after air handler shuts off
Hello, it is possible that the new thermostat has some type of time delay built in it. But typically this would shut of the outdoor unit first and then the air handler.
Jul 25, 2012 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Need help with rth230b
AFTER ST UP. HOW DO YOU PUT IT IN PROGRAM MODE?
Jan 23, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
394 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
