Back to:
Tags:
Sceptre Naga III X30XSV 30 in. LCD Television
No picture and no power LED (by 2 users)
posted by NoCanSee on Apr 20, 2008
I have a Sceptre Naga III X30XSV 30" LCD/TV that is only 3 yrs. old, hardly watched. Recently while watching TV, the picture went out (black screen) and the power LED also went out. I tried made sure the power cord was secure, moved the power plug to another power strip outlet as well as plugging it directly into a wall socket to NO AVAIL. The power LED no longer lights up and there's no picture.
Comment by NoCanSee, posted on Apr 20, 2008
I appreciate your feedback, Nigga-G. However, the TV has been plugged into a surge protector when it went black. I plugged it into another outlet in surge protector, plugged it into the wall outlet, changed the power cable and did the same tests...all permutations did not work.
Still need a solution....
Comment by NoCanSee, posted on May 10, 2008
I ordered a replacement power supply ($65 on the web) for my Sceptre TV and this resolved my issue!!!
It was very easy to replace; on the back of the TV, there's a compartment for the power supply - remove the power cord, remove the 4 screws for the compartment cover, unplug the connector to the power supply and it comes right out.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Bri Mo, posted on Jul 31, 2008
Yes, I'm having the same problem. I'll be watching a show and without notice, the screen goes black (although the voice can be heard). Where can I purchase the power supply that you mention?
Best Solution
Inappropriate (40)
Nigga-G
Rank:Apprentice Apprentice
Rating: 70%, 3 votes
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
Rating Locked! (?) NoCanSee has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No picture and no power LED:
I don't want to Accept this solution
Solution #2
posted on Sep 26, 2008
Not Rated (0)
vtaman
Rating: 0%, 0 votes
anyone with a spectre lcd tv the power inverter is the problem when your tv shows only a blue or black screen it happened to me and i bought a pwer inverter and now it work like new part was 179.00 you have to take apart most of the tv but its worth the hassle and it will save you a lot of money i bought at www.lcdparts.net make sure you know brand and make thx mannyruss
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Flat Panel Televisions problems?
The sound is on but picture wont appear. Have had this...
Sceptre Naga III X30XSV 30 in. LCD...
tv no picture but sound ok. all black
It slowly fades in from white and when it does finally...
I need an owner's manual
I believe these are ballast xformers. There are 8 of...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
