Tevion DV3 stuck on Channel 9 have replaced remote controller batt.
The Hard drive has failed.
Disconnecting the Hard drive will get the tuner going again, but the hard drive will need replacing if you want to record channels.
Posted on Oct 25, 2008
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
_____________________________________
Tevion DVD-200 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Tevion DVD-200 Region Free Fix Would you like to unlock your Tevion DVD-200...
Would you like to unlock your Tevion DVD-200 DVD Player to Region Free?
  1. Press the Menu button on your remote control.
  2. Press the 1 button on your remote control.
  3. Press the 6 button on your remote control.
  4. Press the 7 button on your remote control.
  5. Press 1 for Region 1, 2 for Region 2, and so on, or alternatively press the Mute button on your remote control for All Regions.
Your Tevion DVD-200 DVD Player is now Region Free.
I hope that helps.
_______________________________________
Does anyone know what type of battery is required for TEVION 6592 i-pod dock/player remote control?
https://www.youtube.com/watch?v=1IwMwAzfG_E
This link above shows clearly the remote battery and the batt has a model number and voltage ,check it out
U must help your self or wait for somebody for a long time to help u .
u can also take the remote control to an electrician or a shhop that sells round batt for camera etc Tevion 6592 Tutorial Video
Feb 23, 2015 | Audio Players & Recorders
Tevion LCD32081D can't find code fro new remote
Tevion won't send their manuals for MADs !!!!!!!
Sep 28, 2012 | Tevion Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
Tevion universal remote md 80383 need instruction manual
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Panasonic Televison & Video
Tevion TV set top box remote control code
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jan 01, 2009 | GE JASRM84964 Remote Control
I need a code for a tevion universal remote
Good luck..
Dec 01, 2008 | Universal Remote Control 6-Device...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
