Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Has power supplied to it but doesnt turn on - Cobra 29 WX NW ST 40-Channels Base CB Radio
    Champion:
  • 219 Answers
Is there poiwer going into the radio if so sounds like your voltage regulator is bad.
Posted on Jul 20, 2010
Why my gateway srs wow plasma tv that turns off on its own n sometimes doesnt turn back on
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 05, 2014 | Gateway PLSM50TV 50 in. Plasma Television
Hp pc m7360n no power
after doing this if the power supply fan turns on means your power supply if working fine and if it doesnt work there is problem with power supply.
if the fan turns on and still there is no power there is problem with mother board
May 16, 2014 | HP Pavilion Media Center TV m7360n...
I have a 32inch vizio tv that has no orange light on the logo but when turned on there is a white light and no picture or sound can any one help
The power supply board has some issues with its stand by supplies which should turn the logo orange as soon as its plugged in if the logo doesnt turn orange replace the power supply board You can get the power supply board from www.tvrepairworld.com
Dec 13, 2012 | Televison & Video
It doesnt want to turn on i tried taking out the fuse and puting it back in it still doesnt wanna turn on
Power supply board is dead.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Samsung TX-T3093WH TV
My power brick light is yellow until i turn on the console then it turns red. whats wrong?
The power supply turns red when it detects a fault such as the power supply has to much current, the voltage is too high or the temperature of the unit is too high.
A few ways to trouble shoot this would be .
1. make sure the power supply is cool
2. try plugging the supply directly into the wall instead of a surge protector ,
3. if that doesnt work call 1800 4 MYXBOX and get a new power supply.
Dec 13, 2009 | Video Game Consoles & Games
When i turn the power on the green power supply light goes out and doesnt turn onand the computer wont turn on
Follow these:
  1. Unplug the computer.
  2. Disconnect the power supply from the motherboard and all other accessories.
  3. Replug the power supply.
  4. Connect the green wire (PSON) of the power supply by way of a jumper wire to any black wire (ground).
  5. The power supply should turn on with its fan. If not, it is defective and should be replaced.
  6. Check the ATX12V connector of your motherboard. It is were you removed the 4-wire, 2 yellow and 2 black, connector of the power supply. Check the continuity of the yellow wires to the black ones. It should be open, otherwise it is shorted and your processor is defective and should be replaced.
Aug 19, 2009 | E-Machines Emachine T5026 power supply **...
Push power sounds like it turns on but it doesnt
Discharge the power from the set before you do anything. HIGH VOLTAGE!!! Look at the power supply. It will be in the area where your power chord is soldered in. Toshiba sets are notorious for the mosfet chips going bad. But your problem almost sounds like some bad capacitors. If the mosfets were bad, you wouldn't have any power to your buttons/LEDs. Replace all of the capacitors within the power supply section. They're cheap.
May 24, 2009 | Toshiba 42H81 42" Rear Projection...
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 08, 2008 | Akai LCT3201TD 32 in. LCD Television
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Power supply doesnt turn on
There are several solutions
1. Plugs should be placed correctly
2. The should be power comming into the sockets
3. The voltage switcher should be on the correct voltage... it may be on 220 V while your power in your country would be 110 V so check it
4. Fuse may be blown out
if the 3 dont work contact me again if the fuse may be blown out,, it may be a greater problem
Dec 10, 2007 | Computers & Internet
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
121 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
