Question about Insignia IS-LCDTV32 32 in. Television
Accidentally spilled milk on it - Insignia IS-LCDTV32 32 in. Television
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
Can't clean out spilled (and now sour) milk spill
Hi, I'm not familiar with these fridges, but is it possible to access it from the back, underneath the evaporator tray? It could even be that the milk has gone down the drain hole and into the evaporator tray itself. Its a small flat plastic tray that has raised sides, and will probably have water in in, sits just above the motor
Dec 27, 2013 | Viking Refrigerators
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
After I spilled milk on the burner its not
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 11, 2010 | GE Cooktops
Need to clean the MMI after a spill
did you get a solution for this. I spilled my son's milk in it.
Dec 05, 2009 | 2008 Audi Q7
Spilled milk under the rear seats in my 2006 Ford Fusion SEL.
its not hard, the seats are meant to be removed fairly easily, there are two latches under the seat about a foot in from each edge that have to be released (i think you just reach up under and then its just like a trunk or glove box latch, then push back on the seat and lift up on the front and it should pull out.
Oct 04, 2009 | 2004 Ford Fusion
Smell under the unit, kenmore elite model number 44703
Hi: Not knowing your model number I would look where the milk was spilled and see if there is a hole. Possibly behind a panel for the defrost water. If so pour a little clorox bleach ane water in it. If not look for any cracks in the liner of your fridge. Those will expose the foam insulation to absorb the milk and cause odors. Clean them and seal them with teflon tape or a repair kit from the manufacture. On the off chanch the mild spilled to the front of the fridge and leaked behing the front grill the coils there are quite warm and will spoil milk fast. Pull the grill off and clean. I hope this helps, Jeff
Jul 07, 2009 | Refrigerators
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Spilled milk onto keyboard of toshiba satellite A205-S5800
Well ..Spilling anything on a laptop or any computer component is always a no-no situation. I couldn't tell you what you may have "broke" but I highly doubt that it was just a "fuse"
Nov 18, 2008 | Toshiba Satellite A205-S4617 Notebook
GE PDS20MBS
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Mar 05, 2008 | GE PDS20MBS Bottom Freezer Refrigerator
Insignia IS-LCDTV32 32 in. Television Logo
44 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
