Question about Toshiba Computers & Internet
The clock on my laptop keeps setting to zero when I shut down. It seem to happen after a windows update. I'm running vista. Can anyone give me a solution. I have to keep putting the computer to sleep rather than shut down to avoid the reset. Geoff
    President:
  • 2,600 Answers
It sounds like your CMOS battery is dead. The CMOS battery keeps the date and time current as well as your BIOS settings when power has been turned off to the system. Check your system for the current type of battery your Toshiba uses. It either uses a disc type of battery that sits in a socket, or it has a disc type that is in a covering and attaches to the motherboard via a small cable.
Posted on Jul 12, 2010
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
I have a Toshiba Satellite running Vista and am having all kinds of trouble lately. I'm getting blue screens, trouble shutting down, 'Not Responding', etc errors. I use this laptop for both personal and...
as long as you are not having a hardware issue, windows 7 fixes alot of vistanogo's problems. i would recommend windows 7 professional for mixed home office use and 64 bit. if you are having alot of blue screens, i recommend trying to reload windows to factory settings. the 0(zero) key is the one you press and hold with eht battery out and connected to dc power to get to the restore partition. follow the prompts and reinstall. if this works reinstall all the updates for vista up to and to include service pack 2. then purchase windows 7(do not recommend pirated software because of the risk of viruses and errors). install the update to windows 7 option and repost on your findings.
Dec 07, 2010 | Toshiba Satellite L355D-S7809 Notebook
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and...
information. hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
Nov 11, 2010 | HP Compaq nx9600 Notebook
Gy laptop keeps failing configure updates every time i turn my laptop on. its really annmoying me as every time i go to shut down, it keeps doing the same "installing 1 of 2 updates"
Hi ahzeal,
One thing you can do that make some changes in automatic updates. Just follow is these steps:- 1.Goto Start---->Run. 2.Type services.msc then hit enter. 3.Find out the Automatic updates or windows updates(in case of Windows Vista or Windows 7). 4.Change it to manual or you can stop that(Depends on your wish).
Oct 04, 2010 | Computers & Internet
My Dell laptop is stuck on Windows Vista Home Basic
Press F8 to go to Safe mode, open SYSTEM RESTORE to go back to checkpoint where not yet updated the system.
And next time to open back your system normally finished all updates before you shut down.
Sep 16, 2009 | Dell Inspiron 1525 Notebook
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Hp dv9000 will not shut down or burna disc correctly
What error message is being 'thrown'?
If your system boots and runs take a look at the "Event Logs" on your system. They can reveal a lot of information.
Have you added any new software to your system? Have you had any "Automatic Updates"downloaded and installed? WIN XP SP3 has been known to cause a few problems. Try un-installing WIN XP SP3 and see if this helps.
Do you have a virus program and an anti-spyware program? If you do update them and run them. Let me know what happens. Binary Bob
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
