Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Fuel pump how do i install fuel pump craftsman tractor
4 Suggested Answers
  • 11 Answers
SOURCE: Does not continue to run when choke is not in use.
is the high flow ports on the carb clean? does the engine have good compression?
Posted on May 23, 2009
  • 17342 Answers
SOURCE: I had a replacement engine installed. is it missing a fuel pump?
check inline fuel filter or hose to long between bottom of tank and carb
Posted on Feb 13, 2010
  • 3 Answers
SOURCE: craftsman riduing tractor turns over but won't
Had the same problem. Removed carb, carefully, noting where everything goes and taking some pics, completely disassembled and thoroughly cleaned. Reassembled and worked like a champ. Reason for this? Gas goes bad and gunks up the carb. Good luck
Posted on May 26, 2010
Craftsman lawn tractor mod:917274660. gas not reaching fuel pump. how do I fix? installed new pump. still doesn't work
unhook the fuel line at the fuel pump and see if fuel will flow from the fuel tank. if not there may be a blockage in the tank or bad fuel lines.
Apr 22, 2017 | Craftsman Garden
24 hp Craftsman lawn tractor will not start; doesn't appear to be getting gas in the carb. It is pumping through the fuel pump.
hi Vet68652, I have to agree with tomicamel, it does sound like a clogged fuel filter there is nothing else between the pump and the carb.... unless the line is clogged,
Mar 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
Craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
WHERE IS THE FUEL PUMP ON A CRAFTSMAN 20.0 HP 42" MOWER?
this is a gravity fed system as the fuel take is above the carb and the fuel drains down towards the carb and is fed with a fuel float and a needle and seat valve...good luck
Apr 07, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Feb 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor died while trying to go up a hill
May have a fuel filter or fuel line clogged. Check to see if it has a fuel pump, The diaphragm in the fuel pump may not be pump fuel any more.
HTH
Good Day.
Sep 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
375 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
